| Fairing rudder stuffing boxes...trim tabs My rudder stuffing boxes (twin screw) are mounted to the underside of the hull. Not set up into the hull, like most i've seen. So there is drag and turbulance created by them. I doing some epoxy work, and am considering fairing (around) them. Will the epoxy (west) bond to the clean bronze. Also, on fairing, the trim tabs were installed half assed, and the transom is rotting because of it. While replacing the transom, I was considering mounting a cleat where the trimtabs mount, and fairing it in. That way, when I remount my tabs, the screws go into the cleat and never compromise the transom. Does that make sense? Thanks
__________________ Fire Escape -1987 Luhrs Alura 35. Twin Crusader 454 model 350, MPI, 1.91:1 VD 1969 Thunderbird Formula 23', sadly sold. |
| no takers? Nobody has any input on this?
| Trim tabs | John Perry. | Marketplace | 1 | 09-17-2005 09:11 PM |
| Trim tabs when under power | Nerissa | Sailboats | 1 | 02-17-2005 06:13 AM |
| What happened to keel trim tabs? | mattotoole | Sailboats | 6 | 02-02-2005 01:15 AM |
| Standby OB and Trim Tabs !! | bc575 | Fiberglass and Composite Boat Building | 3 | 10-29-2004 11:35 AM |
| Trim Tabs | stevel | Powerboats | 0 | 09-20-2004 04:13 PM |
