Old 04-24-2011, 08:28 PM
mat j mat j is offline
fairing and paint
im working repainting my hull with awlgrip having a pro spray it but i am getting most the prep work done myself. I have the hull sanded and my transom is bare fiberglass. there are alot of little spots in the hull sides that need to be filled from deep scratches mainly. I am planning on using awl fair and 545 for primer.
I just need some guidance as i am unsure of what steps to take. Do I need to prime my bare fiberglass transom before using the fairing? and should i just fill the spots in my hull and let the shop do the final sand?
Old 04-26-2011, 02:20 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
If you have bare glass use Duratech on the whole hull ! It hi builds and can paint anything at all over the top . Trick is to make it fill even better is add some Q cells to the duatech and it fills even better , Then finish off once you have sanded with straight Duratech ,Block sand the lot with wet and dri !!!!
Making beautiful boats is a passion never a chore !
Fairing H.Y.C Services & Employment 0 03-18-2010 03:06 PM
Experienced Paint and Fairing Supervisor needed insider Services & Employment 6 10-01-2008 09:40 PM
To paint or not to paint over 3m 5200 BurnabyRocket61 Materials 3 09-01-2008 08:45 PM
Fairing bobsyachts Boatbuilding 6 07-08-2006 01:42 PM
Fairing Smircio Software 12 12-10-2005 08:14 AM
