| fairing compound over gelcoat ? I want to start selling my bare cat hulls up to 40 ft .They are male moulded single skined grp polester hulls. All the hulls I have made so far have had a differant end use so it is pointless me fairing them. But to give them a weather coat and to make them look saleable I roll on a gellcoat finnish layer straight over the sanded last chopstrand layer . It looks textured and ok. I use polyester resin and q cell for a fairing compound can that be used over the gellcoated hulls ? Or am I doing it all wrong ? |
| No, nothing wrong with gel and Q, it's one of my favorites, besides, when you use resin or gel as the base for the putty (I often mix them 50/50 for better strength (vinylester, that is)), it's the same material that's underneath. Yoke. |
| 50/50 ? thank you yoke , do you mean 50% gel and 50% vinyl-ester ? p.s What is the correct term for a hull construction method that is a single lay up as opposed to a hull and deck set up? |
| Eloc, Yes, precisely. Since I do a lot of repair-work, I have to do a fair bit of bonding to fully cured laminates, and the vinylester just gives a lot better bond-strength, so consequently, I use either VE or epoxy almost exclusively. As for your second question, I don't know, unibody maybe? Yoke. |
| Spraying gelcoat over gelcoat | alexhiguera | Fiberglass and Composite Boat Building | 9 | 08-26-2005 11:09 PM |
| Gelcoat project on 71 Shark | LtsGo4ARide | Fiberglass and Composite Boat Building | 4 | 07-03-2005 11:02 AM |
| Clear Gelcoat | Dawgfish71 | Materials | 8 | 04-05-2005 01:33 AM |
| fairing compound | HWL | Fiberglass and Composite Boat Building | 18 | 03-19-2005 02:05 AM |
| Gelcoat (sanding) | Saeed | Fiberglass and Composite Boat Building | 3 | 02-16-2005 04:35 PM |
