Old 02-05-2005, 02:01 PM
HWL HWL is offline
Rep: 10 Posts: 18
fairing compound
Is there a fairing compound I can use in the repair of fiberglass boat repair? I use basic car bondo now, but i'm hoping there is an easier sanding option,especially for larger areas. I am by no means a professional, just a back yard builder and repair man. Thanks for your help
Old 02-05-2005, 10:31 PM
Rep: 494 Posts: 3,841
Nothing sands easier than Bondo.
Old 02-06-2005, 09:00 AM
Eric W. Sponberg's Avatar
Eric W. Sponberg Eric W. Sponberg is offline
Rep: 223 Posts: 494
Actually, US paint, makers of Awl-Grip topcoat paints, makes a compound called Awl-Fair which is used extensively in boatbuilding on composite, wood, and metal boats.
Eric
Eric W. Sponberg
Naval Architect
St. Augustine, FL
(904) 460-9494
Old 02-07-2005, 02:38 AM
Rep: 1133 Posts: 4,704
AwlFair works very well, 3M Premium filler works good (vinylester and microspheres), 3M also makes a higher strength filler (vinylester and stranded glass) though harder to sand, Evercoat makes a Bondo like product called Formula 27 filler. I'm reasonably sure Marine Tex and BoatLife also make a filler, though have never used them.
I don't use Bondo type fillers (polyester) I've found they shake out in time if subject to much vibration.
Old 02-07-2005, 07:57 AM
D'ARTOIS D'ARTOIS is offline
Rep: 83 Posts: 1,068
Not only that - it absorps water and finally looses adhesion and crumbles, finally falls apart.
Old 02-07-2005, 11:09 AM
Herman Herman is offline
Rep: 82 Posts: 299
Polyfair from ATC Chemicals. Very easy to sand. www.atc-chem.com, in the polyester dept.
Old 02-21-2005, 06:23 PM
Lew Morris's Avatar
Lew Morris Lew Morris is offline
Industrial Designer
Rep: 10 Posts: 122
not as easy to use (you have to mix resin and filler) but a great product IMHO
West Systems Fairing Fillers:
[url="http://www.westsystem.com/webpages/productinfo/guide/Filler_select.htm"]
Old 02-21-2005, 06:24 PM
Lew Morris's Avatar
Industrial Designer
Rep: 10 Posts: 122
http://www.westsystem.com/webpages/p...ler_select.htm
Old 02-24-2005, 10:29 AM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 279
Our builders like Quickfair by System 3, very good stuff (epoxy based).
Joel
Old 02-24-2005, 07:16 PM
Capt. Chris Capt. Chris is offline
Rep: 10 Posts: 65
West systems 410 fairing compound works well, but expensive. Buy their book on fairing and finishing has lots of good info. Good luck and don't forget a good respirator!!!.
Chris
Old 02-25-2005, 09:28 AM
Phil Locker's Avatar
Phil Locker Phil Locker is offline
Rep: 10 Posts: 71
Joel
Personally I find Quickfair a bit too hard for my liking - similar to the West low density fairing compound (407). It also kicks very very fast. I've settled on West Microlight (410) and then go to a high build primer as soon as possible.
Phil's Foils & Composites
www.philsfoils.com
Old 02-28-2005, 12:12 PM
rxcomposite rxcomposite is offline
Boatbuilder
Rep: 23 Posts: 205
Fairing compound
Ask for a generic fairing compound or micro balloons and mix it with the resin compatible with the boat you are working on. I find it easy to sand.
Dont use cab o sil. It dries very hard like rock. So does resin + fiberglass dust.
After sanding finish off with gel coat mixed with wax solution. You will have to dewax it though before painting.
Old 03-02-2005, 08:16 PM
HWL HWL is offline
Rep: 10 Posts: 18
what sort of wax solution are you talking about? thanks
BOAT=Break Out Another Thousand
Old 03-02-2005, 09:55 PM
If you are going to paint, bondo is fine. It is cheap, sands easily, cures fast and does the job.
Old 03-03-2005, 11:45 AM
Boatbuilder
Rep: 23 Posts: 205
Wax Solution
When you coat gel coat (or resin) as an outer finishing surface it foes not cure as completely as it does when sprayed on the mold as an inner layer.
It cures somewhat but has that "tacky feel" that adheres to the sandpaper when you have to fine sand it. The trick is to add liquid wax solution to the gel coat in the range of 5 to 10%. Its available from resin suppliers.
Resin is hygroscopic, meaning it absorbs moisture in the air. The outer surface exposed to the air does not cure completely or rather takes several days to cure. Did you notice that tacky feel on the last layer everytime you laminate even though it has cured? The inner surface that is in contact with the mold cured completely because it was not in contact with the air.
Wax solution, suspended in the resin, floats to the surface as it cures and seals the resin from contact with the air. The result is a surface that is completely cured or tack free.
Try to experiment with it on a small panel to be comfortable with the effect. Try coating one panel with wax solution and the other without.
Just dont use it on the inner layers when laminating. You will get delamination on every ply.
I suspect Bondo has a wax solution. There is that waxy feel when it dries.
Bondo hull coating EASI54 Metal Boat Building 15 09-25-2005 09:32 AM
Sanding and fairing signum Fiberglass and Composite Boat Building 2 09-19-2005 02:53 AM
fairing compound over gelcoat ? newo eloc Fiberglass and Composite Boat Building 3 07-08-2005 09:18 PM
Spray on fairing material? Capt. Chris Fiberglass and Composite Boat Building 9 03-05-2005 12:23 PM
Hull fairing software (big ship) MaciekP Software 12 03-31-2004 02:24 AM
