Old 10-26-2011, 03:15 PM
skorpio2x skorpio2x is offline
Exposing carbon visual thru gelcoat design visuals
Hey all, first time post here.. got a tricky one here, been trying to research ways on how to do this possibly but seem to be asking the wrong people, hopefully you guys could help out!
Me and a few mates have designed a jetski from scratch finished the tooling mold, and the finished products will be laid up in carbon fibre/kevlar composite.
I've come up with a wrap design (black on white gelcoat) but want to know if its possible to spray on the white gelcoat down first with maybe a template blocking out the design idea, so that when I lay the black carbon on top of the gel, it'll come out exposed once released.
I'll include the wrap concept to give a lil better explanation on what I'm talking about..
Please don't hesitate to ask any other questions or make comments, any info will be greatly appreciated!
Old 10-26-2011, 04:19 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Yes you certainly can mask out the black (carbon) sections but the mould will have to be marked so that you can see where to mask consistently. It will be a pain in the arse......
Did you know that you can get phoney carbon fibre material, it is simply a print, it may be easier for you to have a pattern made up that can be applied to the finished boat as a sticker...there are a few people doing this sort of thing and it is very effective (visually)
Old 10-28-2011, 11:44 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Masking such a pattern is a pig to do, but it can be done.
Do you use polyester gelcoat? If so, use a ty-coat behind it if you want to use epoxy for your laminate, or use a compatible resin (polyester or vinylester).
Your transparent gelcoat should be with MMA added, to improve UV performance. Your supplier should have it.
Old 10-29-2011, 07:10 AM
Rep: 3125 Posts: 9,399
It's much easier to make a faux carbon job, then the actual stuff. Not some much in terms of doing as in terms of durability. A clear coated carbon paint job will last a few decades with reasonable care, not so with the actual carbon showing through. Then of course are the use of black 'glass cloth instead of carbon and the above mentioned printed "veil" products that are available.
Old 10-30-2011, 01:42 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
Picture of it being done in a production mould
http://www.macgregor26.com/construct...nstruction.htm
Old 10-30-2011, 05:58 AM
susho susho is offline
Composite builder
Rep: 62 Posts: 66
Gelcoat is heavy, ty-coats are heavy, lots of work. Why not use paint?
Applying a paint job is some work too, but then your not working in a mould wich is already coated with release.
Old 10-30-2011, 07:49 AM
latman latman is offline
Rep: 14 Posts: 48
that is certainly possible , but it will be difficult to mask up , ps The Kevlar in carbon/kevlar is gold and it will fade to brown over time , and be a pain to repair if ever needed
Old 10-30-2011, 09:34 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Doing exsperimantal designs !! ,then do it on a sheet of clear glass ! Wax a couple of times all over including the edges and reverse side and mask the edges and let the tape overhange the edges !,dont fold the tape down so the product dosent go over the edge of the glass !.
1/4 Inch thick about 500mm x 600mm is a good size to work on when its all gone hard can be peeled off and reused many times Just wax and tape everytime you use it !!.
I have been tryng to duplicate gel coat faults recently buy doing it on a sheet of waxed glass !,its great and You are able to see instantly what you got without all the mystery of having to wait till its gone hard and laying some chopped strand glassing etc etc .
Things that happen to gel coat are easy to understand but trying to reproduce those problems 99% of the time never works .
one i cant reproduce is pigment separation have tried a 20 times and cant make it work!! the old gelcoats it used to happen in the blink of an eye ! The new gel coats dosent seem to happen any more !!.
Wet on wet spray i never get any problems but the guys i work with can never get it right and end up with drifts and colors bleeding into each other all the time . Trying to reproduce what they are doing wrong is a major even when they do it on glass for me it still never works .
Making beautiful boats is a passion never a chore !
Stability software (3D visual) JosephT Software 4 10-14-2010 12:18 PM
Wiring marine Audio / Visual Mat-C OnBoard Electronics & Controls 9 09-22-2009 03:23 AM
Which Hull Should I Use? (Visuals Included) justinDesign Boat Design 2 11-07-2007 09:06 PM
Sail Trimming, Visuals brian eiland Sailboats 0 12-31-2004 10:47 AM
