Old 12-09-2009, 12:21 AM
zamgod zamgod is offline
Rep: 10 Posts: 13
Exhaust Lagging/Webbing
Hi,
I've just been given a present of Glassfibre Exhaust Lagging/Webbing which is about 65mm wide and 3mm thick (unstretched). Stretched it's about 105mm by 1mm.
Can I use this as a substitute for jointing/corner reinforcing tape on my GRP boat?
Thanks.
Regards,
Old 12-14-2009, 01:22 PM
Rep: 1493 Posts: 7,447
In an emergency, probably. I think it would be a waste of money and time. The matrial will be very hard to wet and lay.
Old 12-16-2009, 12:29 AM
Rep: 10 Posts: 13
Exhaust Tape/Lagging
Thanks for the advice.
As a matter of interest, the tape/lagging is fairly soft and pliable and appears to be woven with spaces between the weave. Still no good?
Regards,
Old 12-26-2009, 07:25 PM
partgypsy partgypsy is offline
Rep: 10 Posts: 28
exhaust lagging
Yes... use it for what it was intended. BUT the trick to getting exhaust lagging to fit curved pipes and stay smooth is to wet it... but with water... not resin.
Lukey
http://www.lukeysboats.com
Boat Exhaust 600hp Boat Design 3 05-28-2006 09:35 AM
Gelcoat floor webbing effect dflybldr Fiberglass and Composite Boat Building 2 05-03-2006 11:16 AM
Exhaust location Allan Jennings Metal Boat Building 6 02-08-2006 12:30 PM
Exhaust of FRP Alik Boat Design 8 11-02-2005 08:26 PM
Webbing Solution aguest Boatbuilding 1 01-04-2004 10:00 PM
