Old 02-24-2006, 01:35 PM
rturbett's Avatar
rturbett rturbett is offline
Rep: 22 Posts: 139
Epoxy versus polyester
I've used West epoxy an cloth to make small repairs on glass hulls, with excellent results. If I were to do a large hole repair-1 sq. ft- would there be any reason to go out and get polyester resin to match the hull construction, or am I still ok using epoxy? (not to imply that I'm ok in any other sense... )
Thanks,
Rob
Old 02-25-2006, 11:25 AM
Rep: 95 Posts: 462
epoxy is much better than poly any day much more macahanical property and will bond better to poly than poly to poly
advice on epoxy and polyester craigathome Fiberglass and Composite Boat Building 2 02-20-2006 11:04 PM
How to tell polyester from epoxy? basstardo Fiberglass and Composite Boat Building 10 02-09-2006 02:16 AM
Epoxy over Polyester Blue Heron Fiberglass and Composite Boat Building 6 12-09-2005 12:48 PM
Epoxy versus Cascamite & compatibilities Peter2004 Wooden Boat Building and Restoration 3 06-23-2004 08:00 AM
epoxy or polyester resin gbaaron Powerboats 2 06-20-2004 09:52 PM
