Old 02-03-2009, 08:50 AM
Tevens Tevens is offline
Rep: 35 Posts: 39
"epoxy vacuum basis"
the Baltic 43 old model constructed of kevlar and E-glass hybrid. says it is vacuum epoxy basis what does this mean? does any one know the Baltic 43's production system?
Old 02-03-2009, 02:28 PM
robherc robherc is offline
Designer/Hobbyist
Rep: 102 Posts: 433
I'd guess either Vacuum-Bagged, or Vacuum-Infused. Either one CAN be used in most places the other would, but the Vac-Infusion will give a lighter part so I'd go that way if it's an option for you (steep learning curve, and high risk of ruining the part if anything goes wrong).
Old 02-03-2009, 03:26 PM
limeyus limeyus is offline
Rep: 25 Posts: 13
If it's an older boat then it would be female molded with epoxy resin and the core vacuum bagged in.
Also not sure why everyone thinks that an infused hull is always lighter.....it's not, expecially if each skin is bagged seperatly and the core installation is well done
Old 02-03-2009, 04:01 PM
Designer/Hobbyist
Rep: 102 Posts: 433
Well, ok, then: VIP is my preference as it gives more time to get everything set up "just right" first, without having to worry about the resin kicking while you're trying to get everything set up.
Old 02-03-2009, 04:29 PM
wet feet wet feet is offline
Rep: 99 Posts: 258
I would suspect that the answer lies in the third post and that the translator of the original document lacked the background knowledge to make clear the precise nature of the construction.Would an e-mail direct to Baltic elicit the truth?
Old 02-04-2009, 06:06 AM
Rep: 35 Posts: 39
baltic didn't help very much. any more information would be helpful
Old 02-04-2009, 12:40 PM
apex1
ask the germans
Call or mail them:
http://www.balticyachts.de/default.php?artid=kontakt
they´ll give you the number of the license plate of the lorry that delivered the resin.
Read: they are a bit more helpful than the factory!
For general info about the technique:
http://download.r-g.de/handbuch/handbuch_komplett.pdf
written in German and English, goes very deep through the subject matter (for amateur boatbuilding a must).
Regards
Richard
Old 02-05-2009, 09:09 PM
gamecock413 gamecock413 is offline
Rep: 20 Posts: 15
technicaly vacuum bagged should get 55-65% fiber, infuse 60-70% if your good enough to get it to 70%, then pre-preg shoud be at 70%. So, that says to me all things being equal in set up the infusion would be lighter than the vac bag. Also speaking from experience and burn out tests.
modified linseed oil "epoxy" resin verbertus Boatbuilding 0 06-25-2008 07:40 AM
Runs in "high build epoxy" jmac Metal Boat Building 3 03-15-2007 04:47 AM
Plastic "skin" instead of epoxy cac Materials 8 01-03-2007 05:44 PM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 03:03 PM
"Stupid" Epoxy /polyster question... ErikG Materials 5 05-01-2003 01:39 AM
