| epoxy sealing water in haul?? Grinding woven roving for stringer replacement. foam that was torn out was wet. looks as though roving was put down sloppy. as I'm grinding to rough the surface up I am finding air pockets, some with water in them. Should I grind all the roving out? Otherwise it seems as though the water will get trapped in there and or cause delamination. wanted to use epoxy for repairs. |
| The wet foam, I presume, was originally the core of the stringer? Pockets of air and water are not a good sign. If a bubble is left in place, loads that would normally be spread out over the whole region become concentrated in a small ring at the edge of the bubble. The glass then peels a bit more, the bubble gets bigger, and so on. If they fill with water, the deterioration is accelerated- especially if the boat is stored below freezing in the winter. I suspect you will have to remove the roving over the bubbles and clean them up before you can rebuild the stringers. Definitely use a good epoxy- and make sure the surfaces are clean and prepared with the proper solvents. With due care in the rebuilding process, bubbles and voids can usually be patched, but it takes a long time- patience is definitely helpful.
| Sorry I meant to say the flotation foam was wet. |
| Sealing a motor well? | RHough | Sailboats | 3 | 12-03-2005 02:32 AM |
| Sealing with Silicone? | Ok J | Powerboats | 16 | 06-11-2005 09:45 PM |
| Sealing wood with oil | Big Guy | Wooden Boat Building and Restoration | 27 | 01-10-2005 01:17 PM |
| sealing fiberglass | alvingra | Boat Design | 2 | 08-25-2004 05:52 PM |
| Fuel, water, black water tank construction | kudu | Boat Design | 12 | 07-25-2003 07:54 PM |
