Old 02-13-2012, 05:41 PM
Lister Lister is offline
Moxy
Rep: 45 Posts: 172
Epoxy question
Is a chemical paint remover will remove the epoxy?
The epoxy is on top of plywood.
Thank you
Lister
"I always like walking in the rain," he said, "so no one can see me crying."
Charlie Chaplin
Old 02-13-2012, 07:23 PM
Stumble Stumble is offline
Rep: 604 Posts: 1,086
Probably not. You might be able to use a chisel to remove globs on plywood, but I don't know of anything that will remove it other than sandpaper, a chisel, a heat gun can accelerate the process... But the things that make epoxy suck a great structural material also make it a PITA to remove.
Old 02-13-2012, 07:32 PM
Moxy
Rep: 45 Posts: 172
Thank you stumble. I appreciate.
Now I know that I have to sweat to take apart that epoxy.
Lister
Charlie Chaplin
Old 02-13-2012, 07:36 PM
CatBuilder CatBuilder is offline
Rep: 1316 Posts: 3,040
A belt sander or grinder may work too, if you are steady with them. 36 or 24 grit.
Kurt Hughes was right about this place.
Old 02-14-2012, 09:18 AM
Moxy
Rep: 45 Posts: 172
I have a belt sander, and I am a strong person. I will try.
Charlie Chaplin
Old 02-14-2012, 09:37 AM
Rep: 670 Posts: 2,457
Dont burn up your boat...but...epoxy has a low melting temp . Give a hot gun and a sharp scraper a go. Soften the epoxy then scrap off ,then sand.
Old 02-14-2012, 09:52 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,841
Agreed... remove most of the epoxy with heat and a scraper. Sanding will be much easier afterwards. Make sure you wear a good respirator, have decent ventilation and wear long sleeves, long pants and some gloves...that dust gets everywhere.
Steve Lewis
Lewisboatworks
http://angelfire.com/ego/lewisboatworks
another epoxy question whitepointer23 Boat Design 4 09-29-2011 03:18 AM
Epoxy question keith66 Wooden Boat Building and Restoration 7 08-07-2011 05:12 PM
Epoxy Pinhole Question BobBill Sailboats 17 10-12-2010 07:33 AM
Epoxy question blakey1973 Fiberglass and Composite Boat Building 7 07-16-2007 03:49 PM
epoxy question, zember311 Boatbuilding 5 05-23-2005 11:38 AM
