Old 02-27-2005, 10:24 PM
tropicrows tropicrows is offline
Rep: 10 Posts: 10
Epoxy over Gel coat troubles
I am repairing a fibreglass hull that has quite a few hairline cracks and deep gouges over the hull. I sanded the hull using 180 grit wet & dry and cleaned out the gouges using a small grinder. The hull has been left to thoroughly dry for a few weeks after a good cleaning, and then wiped over with acetone. I have applied some epoxy resin over a small ares to test, the idea was for the resin to weep into the hairline cracks and gouges to seal them before applying any required filler. I used a roller to apply the resin to the hull and it looked good for a couple of minutes, then it all went wrong. The resin formed hundreds of little globules/islands and no amount of brushing or using a roller would give me a smooth even coat.
What has happened???
I have attached a file that show the result, the epoxy has been tinted yellow.
Regards
Bruce
Old 02-28-2005, 08:02 AM
captword captword is offline
Rep: 10 Posts: 79
did you dewax the area to be epoxied? That is what it sounds like your prob was. What brand of epoxy did you use?
Old 02-28-2005, 11:16 AM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
Have you used any wax containing silicons? If that is the case, save your energy. Your hull cannot anymore done this way, forever.
Old 02-28-2005, 07:41 PM
Rep: 10 Posts: 10
That was my first thought, that the hull had some wax or something else on it as well. However it's an old hull and was badly weathered, the Gel coat was oxidized pretty well all over. I gave it a good sanding, washed it with "sugar soap" and finally a good rinse. It was then left to dry for a couple of weeks. Before applying any epoxy resin I wiped it over with thinners and then acetone. I bought the epoxy resin from a local boat builder, he decanted it from a couple 44 drums, I don't know the brand.
Can you test for wax or silicons.
Old 02-28-2005, 07:56 PM
Ssor Ssor is offline
Rep: 10 Posts: 174
Silicones are almost imposible to get rid of. You might have some success with methelene cloride(sp) Maybe try wet sanding and wipeing while still wet. M.C. is nasty stuff wear a respirator and gloves. I have always had to open the cracks up with a small cutter and fill them with thickened resin and then sand .
milky patches in clear gel coat still afloat Fiberglass and Composite Boat Building 3 07-22-2005 04:29 PM
Gel Coat vs Fiberglass pramdx Fiberglass and Composite Boat Building 6 07-18-2005 07:44 PM
I cracked my Gel Coat scarmack Fiberglass and Composite Boat Building 4 06-08-2004 04:54 PM
epoxy to gel coat bonding Guest portpenncrab Boat Design 1 10-22-2003 08:44 PM
Life span of gel coat Materials 0 12-24-2002 03:52 PM
