Old 06-26-2008, 06:27 AM
pjm pjm is offline
Rep: 10 Posts: 3
epoxy needed on clean hull?
Hi , I have a yacht that's never been moored.The hull is foam sandwich carbon fibre.Does it need epoxy coats before antifoul like a fibreglass hull?
Old 06-26-2008, 07:27 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
What type of resin was used in the layup?
Kenneth Grome
Old 06-26-2008, 08:04 AM
bntii's Avatar
bntii bntii is offline
Rep: 1073 Posts: 704
Talk to the builder.
Old 06-26-2008, 08:15 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
pjm,
Even without knowing anything about the build, 300 micron of epoxy can only be a good thing for her lovely little bottom.....just do it.
Old 06-26-2008, 08:53 AM
pjm pjm is offline
Rep: 10 Posts: 3
It smells like fibreglass when I cut holes in it so I imagine it's polyester
Old 06-26-2008, 12:58 PM
Knautcal Knautcal is offline
Rep: 10 Posts: 11
Hi
For the low cost it takes to apply an epoxy barrier paint comparative to future rot is a no brainer. If you have any-doubts about the correct procedure there is plenty of info. available at your local marine paint suppliers and the internet.
Cheers
Old 06-26-2008, 06:40 PM
Rep: 287 Posts: 719
If the layup used any kind of 'ester resin rather than epoxy I would use a barrier coat.
Kenneth Grome
Old 06-26-2008, 07:47 PM
Landlubber's Avatar
pjm,
Just curious, but is the hull really carbon fibre?
It must be some sort of racing yacht, is it an old model or something that you have managed to oick up. Seems very strange to me that such an expensive hull is all of a sudden going to be moored.
What sort of boat is it mate?
Old 06-26-2008, 07:50 PM
Rep: 3125 Posts: 9,399
It's a waste of materials to use polyester on high modulus fabrics like carbon weaves, so it's 99% likely that it's vinylester and much better equipped against blisters. Epoxy could be used on the bottom, as Landlubber and others have mentioned. It will offer additional moisture ingress protection under the bottom paint.
This said, a few manufactures and custom builders are using epoxy in their laminate schedules, so contact the manufacture (again as has been pointed out by others).
Old 06-27-2008, 02:52 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Actually, I have seen, and I still see, carbon being used in combination with polyester resin. Of course it is a shame to waste the carbon that way, but it happens.. I even owned a "carbon hull" Topper Boss, which actually had 2 narrow strips of carbon, 3 meter long, in the hull. Rest was CSM/Polyester...
Everything else already has been said:
-For construction details, talk to the builder (if still in existance).
-Some coats of epoxy on the (sanded) hull will not hurt her in any case.
Also check the inside. If the boat is a hyper-light built boat, the bilge will probably not be coated, but could even be just "peelply surface" (very coarse surface). If water is likely to enter the boat, it is a good idea to apply some epoxy coating in that area as well.
Old 06-27-2008, 03:12 AM
pjm pjm is offline
Rep: 10 Posts: 3
Originally Posted by Landlubber View Post
pjm,
It's a magic 25 sportsboat (about 1996 I think)
THANKS EVERYONE. I'll just go ahead and coat it
Old 06-29-2008, 06:49 AM
Landlubber's Avatar
pjm,
It will not actually be a carbon firbre boat, it may have carbon fibre reinforcings but I honestly doubt very much that it is a carbon fibre boat..1996 remember.
I did some repairs on a Farr 1104 (if i remember right) in 1986, the owner told me it was a carbon fibre reinforced shell, well after crawling into the lazarette area, I can see a single line of carbon fibre vertically every 2 inches. What a load of crap to call that carbon fibre reinforced.
I suppose some dumb arsed lawer would dissagree, as it is in fact carbon fibre reinforced, but to all intents and purposes, it would have done NOTHING, other than allow the salespeople to crap on.
Caveat emptor....
How to clean epoxy from brushes? sandman1984 Fiberglass and Composite Boat Building 49 10-31-2011 10:40 AM
How to clean 30 years of muck out of folkboat bilge jmennell Wooden Boat Building and Restoration 2 11-22-2006 01:56 PM
Correct way to clean 30 years of muck out of folkboat bilge jmennell Sailboats 2 11-19-2006 11:10 PM
keeping props clean david gillam Propulsion 6 08-03-2005 07:13 AM
Keep Lead Ballast Clean John Allen Materials 7 03-25-2005 07:00 AM
