Old 06-27-2008, 01:48 AM
gary1 gary1 is offline
Rep: 33 Posts: 157
Epoxy in mould
Afternoon,
I was just wondering is it possible to use epoxy in a boat hull mould, I have noticed that just about all the questions in regards to laying up fabric up in a mould involves either Polyester or Vinylester types of resin. Is there any other reason besides cost that Epoxy isn't commonly used in a mould.
Thank's
Gary
Old 06-27-2008, 03:43 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
There are 2 main factors why epoxy is used less in a mould:
-cost. For general marine industry, epoxy is too expensive.
-surface. There are no epoxy gelcoats available which survive sufficiently in a marine environment.
About cost:
Of course price of the resin is a factor, however, with a carefull engineered laminate, less resin can be used. A huge cut on fumes (styrene) can be generated, and the boat is upgraded from "grp hull" to "high tech epoxy construction".
About surface:
Basicly there are 2 feasable options:
-1. Apply a good quality polyester gelcoat (ISO-NPG) and apply a vinylester laminate. Let cure, sand and continue with epoxy.
-2. Do not use a gelcoat at all (or apply some sluggish epoxy as a gelcoat, to prevent fibers on the surface) and paint the hull afterwards. (above waterline with PU, below with a suitable coating for the area the boat is used.
Old 06-27-2008, 04:54 AM
Rep: 33 Posts: 157
Thank's Herman,
Appreciate the reply just settled a query that I have been wondering about for a while.
Thank's
Gary
can i make a mould this way? oops! Fiberglass and Composite Boat Building 11 12-17-2007 04:32 PM
mould inquiry Redsky Boat Molds 2 11-15-2006 09:49 PM
epoxy primer sprayed on green epoxy laminate? bntii Boatbuilding 12 10-16-2006 07:41 AM
mould warping rturbett Fiberglass and Composite Boat Building 13 12-07-2005 01:07 PM
Ask Help about GHS (GS mould) zzt9876 Software 1 04-21-2005 08:37 AM
