Old 07-17-2006, 12:17 PM
micag micag is offline
Rep: 10 Posts: 3
Epoxy and marine plywood
It seems that advice abounds about the subject of wooden stringers being repaired or replaced. The fact that they failed in the first place, the blame seems to be on the use of wood and it's tendency to rot. In other posts I read that it's commonly believed that polyester resin doesn't stay well bonded to wood, to use epoxy instead. So it only seems logical that failed stringers can be atributed to the failure of the bond between the wood and polyester resin causeing water penetration and rot. I feel that the use of marine plywood and epoxy is far better than the original method, so wouldn't last far longer than 30 year old stuff I'm replacing?
Datasheets for marine plywood TomE Materials 2 12-23-2005 03:15 AM
wanted: marine plywood snapper340 Marketplace 9 12-06-2005 09:00 AM
Which marine plywood? cyclops Materials 2 11-25-2005 04:41 AM
Repainting a plywood/epoxy hull dave e Wooden Boat Building and Restoration 8 10-27-2005 11:52 AM
mahogany marine plywood structure? blackspot Materials 13 10-06-2004 09:39 AM
