| Epoxy foam as a core material wouldn't be my choice. It's quite brittle, and expensive, and takes a lot of time to make it a core material. PVC foams aren't that expensive, and a lot easier to work with. You could use balsa, but it will be heavier than PVC, and offcourse you need to be carefull with holes through the core. |
| Core Foam ? | fcfc | Marketplace | 1 | 05-17-2011 01:29 PM |
| EU sources for epoxy resins, core foam and laminates? | 28N16W | Materials | 17 | 02-22-2010 04:04 AM |
| Which Foam for Core? | Toby P | Fiberglass and Composite Boat Building | 5 | 05-06-2006 05:44 PM |
| Balsa core vs. foam core | James Maldonado | Fiberglass and Composite Boat Building | 23 | 01-21-2006 10:12 PM |
| Foam core | Hotrod99 | Fiberglass and Composite Boat Building | 9 | 09-06-2005 01:24 PM |
