| Epoxy-Based Gel Coat Recommendations Can anyone recommend an epoxy-based gel coat? I have found one and it only comes in red. Thanks...Alan |
| Yes, what do you plan to do with it? |
| Use it as the first coat in a female mold. |
| You can get it at Composites One. PCT100 SERIES PRODUCTS ECT120 SERIES CCP’s IMEDGEŽ products are high performance In Mold cutting EDGEpolymer technologies that offer unique and revolutionary alternatives to conventional FRP materials. The IMEDGEŽ technologies were developed to promote and drive innovation in the FRP industry. The IMEDGEŽ product line represents CCP’s commitment to be a leader in the industry through technology, sales, technical and customer support. ECT120 SERIES EPOXY COMPATIBLE TECHNOLOGY Copyright 2011 DESCRIPTION: IMEDGEŽ ECT120 coatings are advanced Epoxy Compatible Technology (ECT) products that have been formulated to be used as in-mold, exterior coatings for reinforced plastic parts. Unique benefits of IMEDGEŽ ECT120 coatings are Excellent adhesion to epoxy matrix laminates Deep, dark, rich, high gloss colors Excellent color and gloss recovery after sanding and buffing Blush resistant Excellent weathering resistance. Enhanced impact resistance and toughness for reduced cracking Excellent scratch and wear resistance Resistant to porosity Low weight per gallon IMEDGEŽ ECT120 coatings are formulated to meet EPA’s National Emission Standards for Hazardous Air Pollutants (NESHAP) for both Boat Manufacturing and Reinforced Plastic Composites products. IMEDGEŽ ECT120 coatings offer exceptional water resistance and durable and crack resistant. While offering these benefits, IMEDGEŽ ECT120 coatings have retained the important construction and application qualities expected from CCP coatings, such as resistance to tearing and color separation, sag resistance, consistent liquid properties, and more. These all add up to higher quality appeal in FRP parts made with CCP IMEDGEŽ ECT120 Series products. IMEDGEŽ ECT200 Epoxy Compatible Technology Copyright 2011 TYPICAL PROPERTIES (at 77°F): Typical properties of IMEDGEŽ ECT120 are shown below. These values may or may not be manufacturing control criteria. They are listed for reference only. Particular batches will not conform exactly to the numbers listed because storage conditions, temperature changes, age, testing equipment (type and procedure) can each have a significant effect on the test results. Products outside of these readings can perform acceptably. Test IMEDGEŽ ECT120 Viscosity (1) 7,500-9,500 cps Thixotropic Index (2) 4.5-6.0 (colors) Flash Point 80°F - 84°F Hazardous Air Pollutants (See MSDS for amounts) Volatile Organic Compounds (See MSDS for amounts) Weight/Gallon 8.90 - 9.50 lbs., depending on color Gel Time (3) 11 - 15 minutes Lay-up Time 45 - 60 minutes Sag Resistance Good at 20 mils Hide (most formulations) (4) Complete at 15 mils Notes: 1. Brookfield, RV #4 @ 4 rpm. 2. Brookfield, RV #4 @ 2/20 rpm. 3. 100 g mass, 1.8% Arkema LuperoxŽ DDM-9 4. Reds, yellows and dark blues may have lower hiding power. Ask a CCP Representative whether your red, yellow or blue requires special application procedure (increased film thickness through multiple applications). Refer to the MSDS for handling precautions. MSDS’s will be supplied automatically with the first order for material, and are available by product code upon request from CCP’s Regulatory Department or on CCP’s website at www.ccponline.com. APPLICATION: IMEDGEŽ ECT120 must be mixed prior to use. This includes prior to production spray application and when obtaining material for patching or any material that has been set aside for patching. When not agitated, IMEDGEŽ ECT120 develops a viscous layer at the top of the container. The material at the bottom of the container is much lower in viscosity. Material applied in this condition is likely to sag and have porosity. Mixing of IMEDGEŽ ECT120 is critical to success with the product. Several suitable types of mixing equipment |
| Excellent! Thank you. Unfortunately they recommend spraying only. Do not want to get into that. |
| Spraying is recomended, but brushing works, the directions are for production shops. |
| Thanks again. |
| West System Epoxy incompatible with Gel Coat? | movesnomore | Fiberglass and Composite Boat Building | 14 | 06-13-2009 05:14 PM |
| Epoxy over gel coat? | glasscrafters | Fiberglass and Composite Boat Building | 6 | 02-24-2009 06:36 PM |
| Gel coat/Epoxy fibreglass cloth construction | mikeboatman | Fiberglass and Composite Boat Building | 2 | 04-29-2006 01:06 AM |
| Epoxy over Gel coat troubles | tropicrows | Fiberglass and Composite Boat Building | 4 | 02-28-2005 06:56 PM |
| epoxy to gel coat bonding | Guest portpenncrab | Boat Design | 1 | 10-22-2003 07:44 PM |
