Old 11-16-2009, 02:43 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,145
2 pictures of the object. It has been modified 2 years later because I changed the propulsion (again), but the box is still in place and shows no sign of leakage.
entension/swim platform-newtransom.jpg  entension/swim platform-pic00131.jpg
Old 05-04-2010, 09:07 AM
jeemboNC jeemboNC is offline
Rep: 10 Posts: 54
project status
The builder I am using has missed the completion dates by 7 weeks SO FAR! But I do have some pics to show you of the extension rough mounted. It is VERY BEEFY, but probably not as strong as the 1000# weight and 3/4" thickness would infer (I think the joints are weaker than the panels).
Take a look (two of the three hatch covers are removed). The periphery is glassed in and out, the boat transom and stringers were beefed up, and the face of the extension is bonded and through-bolted (some directly to the four longitudinal bulkheads). The 'sides' significantly reduce the attachment loads and are also very robust.
The upsweep of the tail is to allow water to flow smoothly and to reduce hydrodynamic force when underway (I hope my squat/rise is not much different than current trim). I removed the trim tabs - they were rarely used on this sub-10 knot boat. Will report final sea trial results. FYI - every self-appointed expert within 50 miles has said this won't work!
entension/swim platform-p1040639.jpg  entension/swim platform-p1040640.jpg
Swim platforms Sygeor Fiberglass and Composite Boat Building 0 08-22-2009 12:38 PM
Swim Platform Installation advice needed boatinmi Powerboats 2 08-09-2009 11:01 PM
cheap tubular swim platform / tubular platform supports Paul aka watertaxi Powerboats 0 07-08-2009 04:37 PM
Sink or Swim?? Richard Woods Multihulls 165 06-19-2009 11:26 AM
Installing a swim platform awol46 Wooden Boat Building and Restoration 11 01-02-2007 05:12 AM
