Old 07-28-2006, 06:46 PM
Scotts Scotts is offline
Rep: 10 Posts: 5
Engine Compartment Cover
New to boating. Just pickup a 1985 Horizon 195 Cuddy and i have some parts i need but am having trouble finding them. The main one i need is the engine compartment since the one on my boat is deteriorated. Is there a site that sells them or Should i look for someone to build it or is it something i can build myself? Any help would be great
Old 07-28-2006, 07:03 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Are you talking about the hatch over the motor? On most older small runabouts this is just a plywood box, with vinyl on the outside and engine-room insulation on the inside. Some fancy older boats (and most newer ones) have fibreglass engine covers. The wood version, you can probably build yourself, using the old one as a reference.
Old 07-29-2006, 10:07 AM
Rep: 10 Posts: 5
Appreciate the reply
Do i need to use resin and cloth to make it waterproof and then carpet? What size plywood should i use? Also the old one is so decrepid that i couldnt even use it as a guide is there somewhere i can get the dimensions?
Old 07-29-2006, 11:39 AM
Deeman's Avatar
Deeman Deeman is offline
Rep: 10 Posts: 50
Scotts, I have one that may fit your boat. http://eharder.com/Eric/Boat/Aerocraft08.jpg
It is glass and in good shape. I am changing my rear to a full width sun deck type cover. email me eric@eharder.com if interested and I will measure it and take more pics.
Engine Compartment Cover Scotts Boat Design 1 07-28-2006 07:04 PM
Runabout engine cover LKJR Materials 6 03-13-2006 07:38 PM
insulating deck cover Specmar.Aus Metal Boat Building 9 02-08-2006 01:39 PM
Gas tank compartment ventilation Washburn Boat Design 4 09-17-2004 02:53 PM
stiffness question for engine cover hot for teacher Boatbuilding 14 10-28-2003 05:33 PM
