Old 01-01-2006, 10:33 AM
Troutcatcher Troutcatcher is offline
Rep: 12 Posts: 76
Durability of epoxy-fiberglass coat
Happy New Year!!!
Stitch-n-glue boats are tratitionally fiberglassed, covered with epoxy resin and fiberglass.
For a small funboat thatīs gonna be beached repeatedly........how strong is this coat??? Am I gonna have serious delamination problems with this kind of coat?? Whatīs your experience??
Old 01-01-2006, 11:26 AM
Deering Deering is offline
Rep: 14 Posts: 219
It won't delaminate. The wood fibers will tear apart before the epoxy lets loose. But... you don'y want to compromise the integrity of the seal by gouging the hull and letting water into the wood.
You can do a few things to prevent that:
- add another layer (or two) of glass cloth along the bottom to give you more abrasion protection,
- add beaching strips on the bottom over the glass - sacrificial wood strips, or even better would be UMHW plastic. My skiff has a center keel strip which I attached a plate of aluminum to.
- keep an eye on it - if you put a gouge in it, no big deal. Dry it out and patch it up.
Newby question regarding Epoxy and fiberglass redecking and plywood choices baranx4 Boatbuilding 3 03-05-2007 08:55 AM
Mould less fiberglass construction RAVenous Fiberglass and Composite Boat Building 10 11-24-2005 10:55 AM
Gel Coat vs Fiberglass pramdx Fiberglass and Composite Boat Building 6 07-18-2005 07:44 PM
Need to decide, epoxy, CPES, and/or Fiberglass? Guest Wooden Boat Building and Restoration 30 06-22-2005 12:01 AM
CPES, Epoxy and Fiberglass Questions Guest Boatbuilding 4 09-04-2003 09:06 AM
