| dry inside panel face with infusion When making test panels with infusion I have consistently found the last layer of the laminate stack to be somewhat dry or light in resin. The last layer of the laminate is the one upon which the peel ply rests. For instance: mold fiberglass fiberglass kevlar kevlar peel ply flow medium vacuum bag When the outside of the cured test panel (the smoooth finish side) is struck with a scratch awl or hammer, the inside layer will delaminate somewhat if it is too dry. If it is wet out properly it will lift only slightly in at the point of attack. I tried stacking continuous strand veil on the last layer to aid it wetting it out and it helped but the CSV was somewhat dry. Has anyone dealt with this problem? |
| dry glass This is normal, try reducing the vacuum closer to 25 inches. This will reduce your glass content a bit. |
| Easier way for balsa core deck replacement? | pago cruiser | Boatbuilding | 4 | 06-01-2005 06:20 PM |
