Old 11-24-2006, 07:13 PM
Bentwood Bentwood is offline
Bentwood
Rep: 10 Posts: 21
dry bond problem with coosa/epoxy?
I am using 3/4" coosa bluewater 26 for the sole of my sailboat. I coated the first sheet with 6 oz glass and wet it out with epoxy, like I have done in the past for plywood. The fabric seemed to wet out and bond well. After the epoxy cured, I was cutting out some parts and noticed that I could peel the fiberglass off the coosa by hand. The epoxy was dry, not sticky, and the fabric well saturated.
1. Is this a "dry bond" caused by epoxy being drawn into the substrate?
2. Should I pretreat the coosa board with a epoxy/filler to prevent wicking?
3. Is it really necessary/desiratble to coat both surfaces with 6 oz glass prior to bonding to the hull?
Thanks for your help.
Old 11-24-2006, 07:54 PM
Rep: 95 Posts: 462
when the make coosa board they use a release agent to release the board from the mould , what you should do is rough up the surface so the resin will stick if you dont the coosa will act like a mould
Which epoxy to use on dry rot on a Mahogany Cabin Cruiser? Spin_Drift Wooden Boat Building and Restoration 3 08-12-2006 01:42 AM
Releasing Plexus Bond? Mono Boatbuilding 1 05-17-2006 04:42 PM
Releasing Plexus Bond? Mono Fiberglass and Composite Boat Building 1 05-16-2006 05:28 PM
Thinning core bond putty? Jeffrey Materials 1 06-26-2005 11:06 AM
Epoxy bond to Polyester Ok J Fiberglass and Composite Boat Building 2 04-25-2005 06:18 AM
