| double bias handling Hi, I'm new using double bias (DBM 1708) so as I use to do with mat and roving, I measure my patches ,dry fit them, and carefully roll them .... but with DBM at the moment af the layup I found that they have distorted and dont'fit any more... any secret tip on how to handle this material without losing the shape? |
| Wet them out on polythene sheet, trim the edges and fit the patch into place, then remove the plastic. A light weight flexible polythene is best (75-125 microns) |
| If you do not need the drapability, you could also opt for stabilised DB. This has a small amount of 90 degree fibers, which prevent it from changing shape.
__________________ Slippery when wet. www.cheetahcat.com |
| Use double bias with the 125 gram csm on the back it hold together no sweat . Also comes withA 225 gram csm as well ![]()
| Double Bias? | idkfa | Fiberglass and Composite Boat Building | 3 | 05-09-2009 08:37 AM |
| Waterjet Handling | SparkyDog | Boat Design | 3 | 12-09-2008 11:42 PM |
| hydroplane handling issues ?? | afrhydro | Powerboats | 7 | 07-24-2008 07:50 PM |
| Using double bias fibreglass. | frosh | Materials | 9 | 07-30-2006 04:00 AM |
| Upgrade to better handling | Deeman | Fiberglass and Composite Boat Building | 6 | 07-19-2006 11:42 PM |
