Old 10-26-2011, 11:51 AM
sunbelt57 sunbelt57 is offline
Rep: 10 Posts: 10
diy resin trap
Has anyone ever made a resin trap out of a short length of 3" or 4" PVC? You would just have to get the caps to fit either end and find a way to make 2 connections to the top for the inlet and outlet and then coat the inside with PVA so you could use it again. It would have to be big enough to contain all the resin used in the project to prevent overfilling. You would have to use a large clamp to keep the caps tight because you couldn't glue them on unless you were only going to use it once. That's what I'm thinking anyway.
Old 10-26-2011, 01:48 PM
CatBuilder CatBuilder is offline
Rep: 1316 Posts: 3,040
That's my resin trap. Full length 4" pvc pipe, cut in half so they are 6' sections. Fit hose barbs to the top cap. Seal it all up and throw it out when it's full. Not worth the time and expense to empty it.
Kurt Hughes was right about this place.
Old 10-26-2011, 03:10 PM
Also, after making both "halves" from a full length, be sure to hook them up in *series* in your vacuum line. This way, if one of them fills up during an infusion, you are still protected from resin going to your vacuum pump.
Old 10-26-2011, 11:30 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 336
Same here but.. We built it so a dump gun cup fits inside. When it fills up we can pull off the top and swap out the paper cup. 2 square ends of plastic with a section of PVC in the middle. All thread rod and nuts on the corners. Seal with bag tape.
Typically if you don't have leaks in your vacuum bag you won't be feeding resin into your cup.
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 10-27-2011, 07:07 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
You can just see mine in the background. The trap is PVC with a cleanout on the bottom. Coated inside with vaseline. The second (black) is ABS and just a reservoir. In a dozen or so infusions I haven't gotten more than a drop in my trap. I shut off the supply lines when about 3/4 infused.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 10-28-2011, 10:33 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
PVC pipe, screw-on lids, and Pringles packaging.
Or Aluminium cooking pan, Acrylic lid, and a gasket
were caught in a trap peter radclyffe Motorsailers 31 10-19-2011 06:28 AM
Resin infusion and resin content sorenfdk Fiberglass and Composite Boat Building 23 05-17-2011 07:02 AM
Epoxy resin over poly resin ??? lobsterman Fiberglass and Composite Boat Building 5 05-15-2011 07:37 PM
Trap Pull... Sean Herron Open Discussion: All Things Boats & Boating 0 11-30-2008 02:36 PM
Easy to Build Trap Boat TimClark Sailboats 1 01-22-2006 06:33 PM
