Old 10-14-2008, 08:49 AM
rturbett's Avatar
rturbett rturbett is offline
Rep: 22 Posts: 139
Diviny matching balsa
As I have posted, I love the properties of balsa.
Can anyone tell me how much glass I would need to make 1/4" diviny match the strength of 1/4" balsa core with 10 oz. glass on each side?
Any idea how the weights would compare? (standard grade balsa)
Thanks,
Rob
Old 10-14-2008, 10:34 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
I would think that they'd be very close. Maybe a slight lead to the balsa. IIRC and the experts will correct me, a very high percentage of the strength of a composite panel comes from the glass/resin part of the panel, not the coring. The coring is there to keep the two opposing skins of the panel apart. Some benefit to increased shear/compression properties of the materials can add to the overall effectiveness of the panel but probably not enough to matter overall. Strength is a very ambiguous term to use when trying to describe/determine the physical properties of a composite panel. Sorry I couldn't have been of more help.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Balsa filler rturbett Fiberglass and Composite Boat Building 1 02-02-2006 05:45 PM
toughened balsa mark roberts Materials 6 11-20-2005 02:54 PM
Surface percing propeller matching problem manunk Props 1 06-21-2005 04:12 PM
Matching Mast Sections phillip Metal Boat Building 5 04-22-2005 08:54 PM
Matching Top/Bottom of Molds Guest Boat Molds 1 08-04-2004 08:47 PM
