Old 01-21-2011, 09:17 AM
Capt Ram Capt Ram is offline
Rep: 10 Posts: 11
Dive boat Deck Replacement - Help On how to??
Hi Guys! I’m New to the form and to fiberglass work- I’m working on a project and would appreciate your advice!
I’m replacing a deck on my commercial Dive boat ,8x9 feet- the deck is shot it gets lots of hard use and had a 10 year life-- it was made of balsa enclosed with about 3/16 of glass on both sides- I would like to - replace it once and for all then put her back to work-
What would be the best materials/ methods to use ?
¾ marine Ply with 3 coats on the underside of Epoxy? How many layers of cloth & what weight on top side? I’m taking the 2 top outer boxes out the rest will stay so I need to brace under the area where the boxes are/were supporting the deck what kind of wood should I use? How can I make the deck smooth once I lay down the cloth/epoxy? Any advice you can give will help a lot- What kind of epoxy ? about how much is needed? Thanks in advance!
Old 01-21-2011, 09:27 AM
mark775
What failed on it before? (what were the mechanics of the failure - Water from a crack at an edge, delamination and collapse, puncture?) Are you limited on how thick it can be?
Old 01-21-2011, 09:43 AM
Rep: 10 Posts: 11
Thanks Mark , it had many failures from around the hatches were worn thin from years of tanks being dropped/slid/divers/ and then holed & some screw holes that were not sealed right- to cracks at hatch edges- around the hatches were not built strong enough so flexing occurred on the flange where small cracks let water in and balsa rotted- I’m not limited on how thick it can be
Old 01-21-2011, 11:28 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
With that much abuse expected, plywood is probably the best choice, though it's hard to tell from here whether the balsa-cored deck failed because it was balsa rather than plywood, or, as is most common, from water leaking into fastener holes.
Shocks to balsa could delaminate the core from the skin in any case, so the question is what thickness of plywood to use.
3/4" might be overkill--- depending on frame spacing and spans. A good quality marine grade plywood is inherently stronger than off-the-shelf box store plywood, and much more expensive too. It may be that 1/2" would do, but again, only if the frames are close enough to minimize flex.
However thick the balsa core was, that's going to be about what thickness the plywood should be, so long as the old deck failed due to reasons other than balsa thickness being too thin.
It might also make sense to thicken the top skin to 1/4" for better impact resistance. Rubber mats, if appropriate, would go a long way towards cushioning the deck from abuse in the future also.
Aft deck replacement dlp90731 Boatbuilding 3 03-15-2010 03:43 PM
Dive/Fish jon boat? spearaddict Wooden Boat Building and Restoration 12 02-28-2010 02:40 PM
Deck Replacement instigator Fiberglass and Composite Boat Building 12 04-20-2007 05:54 PM
Deck replacement Busted Knuckle Materials 0 03-31-2004 04:02 AM
dive boat hull cubano Boatbuilding 1 08-06-2003 07:47 PM
