Old 10-06-2010, 10:41 PM
SeaJay SeaJay is offline
Rep: 112 Posts: 211
Diatomaceous earth
Does anyone have an experience using DE (Diatomaceous earth) as an epoxy filler? I ask as I have a bunch of it (used as a swimming pool filter medium) and also remember it being recommended as an admix for ferro cement construction. Anyway, I was wondering what its properties might me as a filler material.
Old 10-06-2010, 10:54 PM
WestVanHan's Avatar
WestVanHan WestVanHan is offline
Rep: 413 Posts: 657
Sorry can't help you with that,but food grade DE really knocks down cholesterol levels
I think it's bad luck to be superstitious.
Old 10-06-2010, 11:24 PM
mark775
The closest I have come is using vermiculite and perlite, both of which have a tendency to float in the epoxy - especially perlite. DE is a little denser so give it a try and let us know how it works!
Old 10-07-2010, 12:57 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,025
Make sure you pick the cat poop out of it first.
Old 10-07-2010, 01:25 AM
Rep: 501 Posts: 1,767
Really ?
Old 10-08-2010, 05:12 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Be careful not to breathe it in. It will cause silicosis in the lungs.
Having said that, I also consider it for making epoxy putty. It should be very durable, but abrasive.
http://www.lungusa.org/lung-disease/silicosis/
Hoyt
Old 10-08-2010, 06:59 PM
Rep: 3125 Posts: 9,399
Mildly abrasive, but I'm concerned about it's absorbent qualities being more problematic.
Old 10-08-2010, 08:47 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Food grade DE has much less risk to the lungs, although it still exists so avoid breathing in the dust.
-Tom
Old 10-09-2010, 11:21 AM
Rep: 1493 Posts: 7,447
I believe the water content is quite high. They make it to filter water after all. If there is water in it, the epoxy mix won't cure.
Old 10-09-2010, 11:30 AM
srimes srimes is offline
Rep: 186 Posts: 226
Huh? I thought water was an accelerant? Still not something you want...
Old 10-09-2010, 11:41 AM
mark775
"They make it to filter water after all" - Gonzo will periodically lapse into non sequiturs as if...well, never mind. Just ignore this. Of course, use dry DE.
Old 10-09-2010, 11:46 AM
Water is not an accelerant for epoxy. It will make it become a gooey mess.
mark775: What do you mean "ignore this"?
Old 10-09-2010, 02:33 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
water is an accelerant, for a couple of epoxy curing systems. I managed to speed up a 300 minutes system to 20 minutes cure time, by adding less than 5% water. It also creates a lot of bubbles, by the way.
Old 10-09-2010, 04:25 PM
mark775
Because something absorbs water HAS NO BEARING on if it actually has absorbed water. Because it is used for filtration HAS NO BEARING on its propensity to absorb water. Wood absorbs water, for goodness sake.
"Water...will make it become a gooey mess." _ You are thinking of poly here. Most epoxy just tends to fail to adhere.
Old 10-09-2010, 05:40 PM
hoytedow's Avatar
Resistor
DE is just glass. Silica dioxide, if you will. It is not hydrophyllic like salt. It is fairly inert. It is used in parmagian cheese as an anti-caking agent. It will tear the cells in your lungs because it is very sharp.
Hoyt
earth in a steel yacht bigbear69 Metal Boat Building 22 01-21-2012 11:58 AM
Earth Race fhrussell Multihulls 24 08-29-2011 02:35 AM
Fastest Sailor on the Earth ?? brian eiland Boat Design 1 04-06-2009 01:06 PM
Google Earth MikeJohns Open Discussion: All Things Boats & Boating 48 06-06-2007 08:46 AM
earth race longliner45 Open Discussion: All Things Boats & Boating 6 05-07-2007 08:19 PM
