Old 10-09-2010, 10:07 PM
mark775
I thot it was dead little plants.
Old 10-10-2010, 02:20 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
I did some reseach, and of course started here: http://en.wikipedia.org/wiki/Diatomaceous_earth
DE is Kieselgur. A natural form of Fumed Silica. The industrial produced types have brand names like cab-o-sil, aerosil, fumed silica, amorphous silica, colloidal silica, whatever you name it.
Which makes life simple, as this is being used in composites all the time. Usually your thixotropic polyester resin has it, gelcoats, epoxy glue, etc.
But also bread, cheese, drugs (Fumed silica makes ingredients flow better during production) and many more applications than you would like.
DE is a natural material, and comes in many variaties, many with more or less wanted properties. Some are very sharp, some are cristalline, causing silicosis. Some are amorphous, which is the form that equals the fumed silica made industrially. The above mentioned link provides some good info.
Old 10-10-2010, 09:13 AM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
A quote about safety, from Herman's link - for those who don't want to read the whole article.
Safety considerations
The absorbent qualities of diatomite can result in a significant drying of the hands if handled without gloves. The flux-calcined form contains a highly crystalline form of silica, resulting in sharp edges. The sharpness of this version of the material makes it dangerous to breathe and a dust mask is recommended when working with it.
The type of hazard posed by inhalation depends on the form of the silica. Crystalline silica poses a serious inhalation hazard because it can cause silicosis. Amorphous silica can cause dusty lungs, but does not carry the same degree of risk as crystalline silica. Natural or dried diatomite generally contains very low percentages of crystalline silica. Diatomite produced for pool filters is treated with high heat (calcining) and a fluxing agent (soda ash), causing the formerly amorphous silicon dioxide to assume its crystalline form.
The crystalline silica content of the dust's particulate is regulated in the United States by the Occupational Safety and Health Administration (OSHA), and there are guidelines for the maximum amounts allowable in the product and in the air near the breathing zone of workers.
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Old 10-10-2010, 11:11 AM
Herman's Avatar
Resininfusion.info
Thanks for quoting, health is an important issue. Protect yourself!
Old 10-10-2010, 11:42 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
In it's pure form it is simply diotom skeletons minied from old sea beds where they settled to the bottom after dying many years ago.
Breathing the dust has a cumulative damaging effect so is to be avoided. The skeletons are razor sharp and very small (5 - 30 microns).
They make for a terrific parasite controller in the gut of any mammal (food grade only) and a fantastic pest suppressant in the
garden when applied in a water solution.
Around here, it can be purchased for $2US - $10US per kg (food grade) depending on quantity.
-Tom
Old 10-10-2010, 07:34 PM
SeaJay SeaJay is offline
Rep: 112 Posts: 211
Thanks for all of the feedback. I'm not worried about the health issues...its like anything else, use proper precautions. It can't be any worse to breath than microballons or cabo-sil. I think I'll give it a shot as I have a bunch of it for my pool filter and it is less money than cabo-sil.
Old 10-12-2010, 05:02 PM
Rep: 1493 Posts: 7,447
Microballoons are not too bad. Cabosil is. My concern with it, is that fumed silica sold as a load for epoxy is water free. Something sold to be used as a water filter may not need to be.
Old 10-15-2010, 02:37 PM
Herman's Avatar
Resininfusion.info
I have no idea of the situation in the UK, but here most fumed silica is Aerosil (Degussa) which is relatively water-free. I do however suspect that it is slightly hygroscopic. Once I get my industrial oven (it is ordered) I might run a test by heating a 20 liter pail with Aerosil for a while, and weighing it before and after (I have a 5000 gram scale, in 0,01 gram increments)
Old 10-15-2010, 04:12 PM
Aerosil and Cabosil are the most common brands. They are very hygroscopic. If you leave the container open they make lumps and eventually become solid. Fumed silica has be treated at high temperature.
earth in a steel yacht bigbear69 Metal Boat Building 22 01-21-2012 11:58 AM
Earth Race fhrussell Multihulls 24 08-29-2011 02:35 AM
Fastest Sailor on the Earth ?? brian eiland Boat Design 1 04-06-2009 01:06 PM
Google Earth MikeJohns Open Discussion: All Things Boats & Boating 48 06-06-2007 08:46 AM
earth race longliner45 Open Discussion: All Things Boats & Boating 6 05-07-2007 08:19 PM
