Originally Posted by SOB What is involved in damming a mold in a v bottom with full length strakes. Can a insert be installed to achieve shorter lengths without damaging the mold? |
If the transom has detail, convolutions, etc. that you want to reproduce, you can splash a temporary transom mold off a completed boat and fit it to the mold or if you have no completed boat you can lay up just the transom in the mold, take that out and then splash a temporary transom mold from it and then fit that to the mold. A few L-brackets can be screwed to the inside of the mold to hold the temporary mold in place, when you are done the holes can be plugged with Bondo or something and then waxed over, they won't be noticable in subsequent hulls. Not a whole lot of attachments are needed, just be carefull when rolling and working the first few layers of glass to not shift anything, after a few laminations it sort of self supports. Although it doesn't take much support for laminating, if you have to use heavy clamps for installing a plywood core, you have to take that into consideration. You can radius the corners with modeling clay stuck in them and then formed with a waxed socket wrench socket of the appropriate radius pulled along the corners. Sam
