Old 02-15-2010, 09:29 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
Cutting a roll to make tape
Has anyone cut their own tape from a roll? It seems like an economical way to go about it. I'm just not sure how to or what would be the best method. Any ideas>
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 02-15-2010, 11:25 AM
Hunter25 Hunter25 is offline
Rep: 46 Posts: 173
Edges would unravel badly.
Old 02-15-2010, 11:38 AM
Rep: 572 Posts: 646
On cloth it's a disaster. You'll need also a very good saw - diammond saw works best-. It works on biaxial if you have the very good saw. For a small project, counting the price of the saw, the blades, the time spent and all the material lost during the trials, it's not worth.
Old 02-15-2010, 01:53 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
I've tried- as Hunter and IV suggest, it doesn't work very well. Without the woven edges of a true tape, the home-cut stuff just unravels at the edges and makes a mess.
Old 02-15-2010, 02:09 PM
Rep: 578 Posts: 615
Just got a call back from the guy. It's 1708 biaxial so I'm guessin' that won't work either. If ya don't know ask eh?
Thnx fella's.
Old 02-15-2010, 03:09 PM
mark775
Yes, IT WORKS. It requires a different blade (I don't know the blade, a "roll slitter"). The manufacturers do it all the time (I get mine in the widths I want), for example a 38" roll cut into thirds, quarters, sixths, or halves. I get veil cut into 3.5" tape. Call the glass guy again and he'll tell you if it a blade you will want to afford. Simple just to order what you want.
Old 02-15-2010, 06:19 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
If you can find a long enough hand saw then sharpen the blade's teet to a rough smooth similar to the steak knives you get just finer teeth like you get with a course grinding wheel. It mustn' hook the strands, just the fibers.
A foam cutter like these electric bread knives also cuts the glass faily well. Electric bread knives are too light for the job. I bought the biggest foam cutter and it just makes it.
The sides does ravel out a bit, handle carefully.
Regards
Fanie
Water ! Just gimme water !
Old 02-15-2010, 06:44 PM
Zed's Avatar
Zed Zed is offline
Rep: 179 Posts: 261
I thought it was doable with a band saw?
Never trust someone who can't say 'I was wrong'.
Old 02-15-2010, 07:09 PM
Rep: 578 Posts: 615
Thnx Fanie. If found the old thread where we discussed this before. I've looked at those foam cutters $$$$$ yikes. I know a guy who's a whiz at sharpening knives and I'm gonna ask him for ideas.
Old 02-15-2010, 07:19 PM
Rep: 578 Posts: 615
Gonna give it a try! Small scale though, see what happens.
Old 02-15-2010, 10:42 PM
Rep: 572 Posts: 646
It's feasible with a band saw. In fact it's the best tool for that if you use a blade made for that. Diamond blades that look like the tile or hard stone blades give the best results at my knowledge and experience. An important thing is to warp the roll with wire or anything convenient each side of the cut line, very tightly. The purpose is to forbid the glass layers of moving and sliding.
Good mask and goggles are mandatory.
Old 02-15-2010, 11:11 PM
Zed's Avatar
Zed Zed is offline
Rep: 179 Posts: 261
I think I saw pictures of a guy compressing the roll with cling wrap then cutting it?!
Old 02-16-2010, 09:59 AM
Rogue Wave Rogue Wave is offline
Rep: 10 Posts: 4
I do it all the time Fanie's way, and it's super easy.
Start with an old wood hand saw, then use a 36 grit disc on a 5000 rpm (or whatever) grinder to sharpen the opposite side (not the side with teeth).
You just want to put a little bit of "bite" onto the edge, not make it perfectly sharp.
Wrap masking tape around the area you're going to cut, then cut through it so it doesn't unravel.
Rotate the roll as you cut.
You'll be amazed at how quickly you can cut through a roll of cloth if your saw is set up right.
Good luck and I hope this works for you!
Old 02-16-2010, 11:39 AM
fcfc fcfc is offline
Rep: 359 Posts: 709
See www.tissa.ch/e/dokumente/matcut_allgemein.pdf
and http://www.youtube.com/watch?v=LfbTbYdGBmg
Twin alternating blades saw.
Old 02-16-2010, 12:37 PM
Rep: 578 Posts: 615
Thnx Rogue
Ahhhhhh Wasaga Beach! Brings back some fond memories!
Thnx again.
Sticky Tape 02... Sean Herron Open Discussion: All Things Boats & Boating 12 03-24-2009 03:32 AM
Sticky Tape... Sean Herron Open Discussion: All Things Boats & Boating 5 03-18-2009 02:45 AM
New Teak Deck Caulking: Tape or No Tape? Scott Carter Wooden Boat Building and Restoration 5 07-10-2007 01:50 AM
CNC cutting file....need to make one. MikeJohns Software 6 02-08-2006 09:40 AM
Force needed to roll or counter roll fer_mayrl Boat Design 1 02-13-2004 03:21 PM
