Old 05-20-2010, 07:49 PM
kirkster7 kirkster7 is offline
Rep: 10 Posts: 4
custom fishing boat
Hey guys i need alot of input on building a fiberglass boat from scratch. I would like to build a boat that like a nitro bass boat. I was thinking of building a wood skeleton, filling in the spaces with high density foam, then covering everything with fiberglass. Is this a good idea? Is this possible? Any input/advice would be greatly appreciated. I need some expierneced advice.
Thanks guys
Old 05-23-2010, 02:32 AM
Stumble Stumble is offline
Rep: 604 Posts: 1,086
Kirk,
Can it be done? Yes
Is your methodology a good one? Not really
Is this a cost effective way to get a Nitro? Absolutely not
As a general rule it costs as much to custom build a boat as it does to buy a similar boat new. Therefore the justifications for building can be generally grouped into a few catagories 1) What I want isn't and wasn't made by someone else. 2) I want to build a boat.
On a small bass boat the reality is that the engine will make up a very significant part of the cost of the boat (well over 50%), and used boats are cheap. My advice is buy an older one, and repower it.
Old 05-23-2010, 08:07 AM
Eric Sponberg's Avatar
Rep: 2547 Posts: 1,426
It would be better to build it out of plywood and epoxy, and coat over with two layers of fiberglass cloth and epoxy. You will get a sounder structure provided you have a good structural design, and it will ultimately be easier to build, look better, and probably cost less money in the long run.
Good luck,
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 06-03-2010, 05:35 AM
wdbeyer wdbeyer is offline
Rep: 10 Posts: 7
Ditto on the above two posts. Take a look at Glen-L's Flats Flyer or Bateau's Phantom. You could take either design and modify the interior space to your own liking, i.e. like a Nitro.
Custom Fishing Boat kirkster7 Boat Design 6 03-14-2010 10:27 PM
Custom Boat Kits bamaboats Boat Design 0 07-17-2008 08:10 PM
How much is it for custom boat design? IamSam Boat Design 18 05-13-2008 09:33 PM
custom jon boat chodedawg Metal Boat Building 5 08-24-2006 06:38 AM
Custom maker of fishing boat molds 10 - 30 ft Gilmarine Boat Molds 0 10-08-2004 05:41 AM
