| Correct method to join fibreglass panels I have two section of fibreglass which a need to butt up against each other and join. I was going to use polyester resin with 4 layers 450gm CSM on the un-seen side. Then I was going to grind out the front joint line to about 20 mm wide x 1 mm deep and fill this with epoxy filler. Is this suitable method or should I be adding some reinforcement to the front side as well before filling, or should I be doing the whole job differently. The last thing I want is a cosmetic crack appearing at a later date. All advise appreciated. |
| If you do not want the crack to appear, beef up the rear side as you suggest, then grind out the front, tapered 1:8 or even 1:12 and replace the lost glass nicely. Sand smooth, re-gelcoat or paint.
| Bit of a knowledge gap here. What kind of pressures are going to be applied to the panels - are we talking structual hull, inner shell, deck, cuboard doors ,8x4, 6inches by 18inches Thickened epoxy might be enough for some applications. |
| Whatever the use, herman has it about right anyhow.
| Failing to taper the repair, which it is basicly, will always make the crack re-appear.
| It wouldnt be enough for exterior hull with high loadings - you would need inner and outer laminations, and not just of chopped mat either. |
| Thanks Herman, the joint in on the inner shell in the deck area. I will go with the 1:8 tapper fill with glass and then finish with epoxy filler. |
| Scarfing, Splicing, join for Ply | gary1 | Fiberglass and Composite Boat Building | 16 | 11-30-2007 12:50 AM |
| Best way to join deck to hull of kayak? | Grantman | Fiberglass and Composite Boat Building | 6 | 11-28-2005 09:41 AM |
| Invitation to join SNAME technical panel | wlasher | Sailboats | 9 | 07-13-2005 12:53 PM |
| Deck and house join material | Tamarak | Fiberglass and Composite Boat Building | 3 | 01-07-2005 05:18 PM |
| Join in a Co-operative Catamaran Build Venture! | Neven | Marketplace | 0 | 12-17-2004 02:20 AM |
