Old 12-18-2009, 01:54 AM
Xander Xander is offline
Rep: 23 Posts: 12
Corner Fillets / Inside Radius Creation
I am trying to find the best / easiest / cheapest way of filleting the corners of a melamine mold (female mold with unwaxed polyester gelcoat & resin layup). I went out and bought the ingredients to make a few gallons of home-made modeling clay. After the first test batch, I'm not convinced that it will work as well as the non-drying store-bought clay that is traditionally used in mold making. My plan, as of now, is to use drywall mud and a popsicle stick. Anyone have experience with this technique? Anyone need a dozen boxes of corn starch and a 20 pound bag of table salt? Thanks in advance for any suggestions & advise.
Old 12-18-2009, 02:37 AM
mark775
I just use bondo for quick radii. You can bye wax fillets and a heated round tool that works quite well.
Old 12-18-2009, 02:08 PM
keith66 keith66 is offline
Rep: 117 Posts: 223
Polyester filler (Bondo) for hard mould or plasticine for instant one off result, warm it up & fillet it with ball ended tool.
Old 12-18-2009, 02:25 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
When making rounded fillets, try a piece of alloy tube to the desired radius.
Sand gently the cut edge then drag it along the track that you wish to fill. The alloy will leave like a pencil mark in two places (where it touches the sides). Use these lines to mask using fine line plastic tape, and you will have perfect one off rounds when you use the same tube to scribe in the bog. The tape lines are perfectly placed to leave the minimum residue naturally. Peel off the tape over itself to cut a nice fine and even edge.
Hope this helps, if there is anything not understood, please ask.
Old 12-18-2009, 06:26 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 336
Neat trick! I'm gonna' try that next time.
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 12-18-2009, 07:12 PM
Elmo Elmo is offline
Rep: 170 Posts: 32
Yes , that does work well.
I have used PVC pipe in the same way.
Slightly damp rag wiped over the pipe prevents dragging the filler.
Old 12-18-2009, 09:29 PM
Landlubber's Avatar
Sure, use any medium you like to make the fillet, but it is the line drawn for the masking that makes the job perfect.
You can of course mask out from the sides by the thickness of the radius, but the alloy tube simply draws that line for you.
Old 12-18-2009, 10:21 PM
mark775
Yes, that is good. Thanks Lubber. Most know this but long runs of tape are much better than short, never lay your fine line down on edge, particularly in a dusty shop. Reminds me, I can't buy fine line in my town because they always put a price tag on the edge of the roll and handle it roughly!
One more thing, When using Bondo, even when waxed, my part sticks in places. I don't want to spray PVA every time I need a small part - any secrets? ( I am going to try this Plasticine stuff. I Never use modeling clay because it dries out mid-job and creates a mess.)
Old 12-19-2009, 02:02 AM
Rep: 23 Posts: 12
Thank you for your ideas and suggestions. I have tried several methods and materials and had very little luck with most. Threw a few trials at the wall. Finally, I got a great result using Plasticine. My home-made clay was water based and it seems rather critical that it is instead the non-drying oil-based "Plasticine" style of clay. I custom built a radius tool out of an aluminum rod and a perfectly round cast iron ball. Heating the cast iron ball by dunking it into hot water allowed me to shape and smooth (nearly melting) the clay to a near perfect finish. With the tape lines in place (nicely pre-marked by dragging the ball along the corner as suggested) the result is gorgeous compared to earlier attempts.
Old 12-19-2009, 02:15 AM
mark775
And then you wax the flat surfaces, or they were waxed first as this stuff is soft?
Old 12-19-2009, 01:30 PM
Rep: 23 Posts: 12
Typically, I think the mold is waxed first and then one final (careful) wax coat is applied after the fillets. But in my case I am using a heated tool to apply the fillets and I suspect that would melt the wax instantly so I plan to do all of my waxing after applying the fillets. The clay that I'm using stays nice and stiff in colder temperatures so I'm not worried about waxing after filleting - although the clay is still malleable so I will need to wax very carefully in the corners. The clay almost has the consistency (and mine is blue so it also looks) like a racquet ball. With a soft touch it could be called "hard" but if you poke it with a finger it will dent and deform easier than a racquet ball - it's neat stuff.
Old 12-19-2009, 01:35 PM
mark775
Thanks, I'll get some.
Old 12-19-2009, 06:47 PM
jim lee's Avatar
Rep: 217 Posts: 336
The trick with PVA, at least what we do, is to wipe it on with a rag. We just use pieces of T-Shirt. You should not be able to see the green tint from it. Doesn't take much.
-jim lee
J/35 No Tomorrows
Old 12-19-2009, 08:18 PM
mark775
And you're sure that it's doing something beyond what the wax does?
Old 12-19-2009, 11:41 PM
Rep: 23 Posts: 12
-jim lee
I don't think I'll be using PVA. I figure the wax should be fine.
radius chine == radius bilge ? greenwater Metal Boat Building 9 12-14-2010 04:00 PM
Adviser needed for creation of a new boat concept D.I.M.1 Services & Employment 8 12-09-2009 12:11 PM
Fiberglass taping an inside corner MarkIFC Fiberglass and Composite Boat Building 13 12-15-2007 10:47 PM
Rhino Surface creation question Arvy Software 3 08-15-2007 05:47 AM
Plasticine fillets and alternatives Dresca Boatbuilding 6 06-03-2007 02:51 AM
