| Core in a mould ? Hi, Just finally getting underway with our 35' workboat mould. Wondering about cores. Most of mine have balsa. Has anyone any thoughts about using nidacore in a hull mould? I was wondering about using 3/8" nidacore possibly vaccuum bagged on. Hull has quite alot of fairly flat panels. Any advice appreciated. Neville, Scotland |
| We are planning on using nidacore on some canoe bottoms. I think that you need to vac it on to get good adhesion and no voids.
__________________ Gonzo |
__________________ Slippery when wet. www.cheetahcat.com |
| Its for bulding the mould itself. I have used it many times on boats typically on flat panels, but for a mould the panels have a slight bend so the only way I could see would be to use a vacuum bag system. |
Here is the last little bit of 3/4" core going down on a 38' hull mold ,there are perforations which allow the excess material out to the surface and maintain a consistent bond line this is bedded in ATC Corebond. ![]()
| We infuse our molds with core, glass and most of the framework in one shot. So yeah, core's good. -jim lee |
| That would not work here, I use a lot of piping on the production molds. ![]() And they have to be perfect, This one 38 ' is a inch thick solid glass ,nice pull here. ![]()
| Piping's not a problem. You can still add that after the mold is shot. We like infusing 'em 'cause you can build in more overall rigidity in the one shot. By using core and balsa ribbing. Once its shot, we'll add the final framework or what have you. Granted our surface quality isn't perfect. But for what we do, its plenty good. What we really want is parts that are dimensionally accurate and infusing them has helped a lot in this respect. -jim lee |
| I could have infused this as I have my own system ,KRYPTON which I have been working on for 20 + years. But the all Molds here had to be first rate. ![]()
| For cores in moulds, Nida would not be my first choice, for the relatively low shear modulus. For approx the same amount of money you have balsa, which gives a stiffer product. On the other hand, if it is Nida that you have, go for it. It is not bad, just less "perfect", just "good".
| Herman, Why go with a balsa core? In my opinion I would always ago for a non-wood, closed cell core when possible. If would look for a PVC or PET foam. I think Airex has both of these types of core. Unfortunately, the youngs- and shear modulus will be significantly lower. Cheers, Coen |
| You are right, but not for the same money. Balsa still gives the highest shear modulus for the buck. PET (Airex / A3 Composites T90 and T92 foams) is also an option indeed, but I would check where that ends up in the shear modulus / cost ladder.
| OK by who's numbers??
| I do not get the question.
| You said balsa gives the highest sheer numbers and I asked by who's numbers?
| getting that mould perfect | gages | Fiberglass and Composite Boat Building | 14 | 05-14-2010 08:05 PM |
| Foam core in a female mould | Highwater | Fiberglass and Composite Boat Building | 1 | 06-14-2009 02:40 AM |
| can i make a mould this way? | oops! | Fiberglass and Composite Boat Building | 11 | 12-17-2007 03:32 PM |
| Balsa core vs. foam core | James Maldonado | Fiberglass and Composite Boat Building | 23 | 01-21-2006 10:12 PM |
| need help for mould preservation | mechatics | Fiberglass and Composite Boat Building | 3 | 04-01-2005 09:56 AM |
