Old 11-27-2010, 02:48 PM
Coen Coen is offline
Rep: 39 Posts: 30
The shear modulus of a balsa 100 kg/m3 is around 110 N/mm2. PET (Airex T92) will give you a shear modulus of 21 N/mm2.
Old 11-27-2010, 02:59 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Manufacturers. (edit: Thank you, Coen)
For moulds stifness is what counts, more than impact resistance (people working your tool with a sledgehammer should be ehhmm, eliminated).
But as I stated: All types of stiffening is better than no stiffening at all.
Old 11-27-2010, 03:05 PM
Rep: 39 Posts: 30
Sorry, I didn't see / forgot that it was concerning the mold. I thought it was about the hull. Sorry for that.
For the mold, go with balsa.
Cheers
Old 11-27-2010, 03:55 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
Cheers
Never will use wood , but see post #9
Slippery when wet.
www.cheetahcat.com
Old 11-27-2010, 04:00 PM
Rep: 84 Posts: 661
I have built a lot of first rate molds and chose to use first rate material every time,Yes balsa will work but why use a second rate core in block form of varying density.
Slippery when wet.
www.cheetahcat.com
Old 11-27-2010, 04:39 PM
Rep: 84 Posts: 661
Point is some of the testing methods do not work on the resilient cores. Once again, when they do what you pay the big money for the test will indicate that movement as failure and mark that as a absolute value.
Slippery when wet.
www.cheetahcat.com
getting that mould perfect gages Fiberglass and Composite Boat Building 14 05-14-2010 08:05 PM
Foam core in a female mould Highwater Fiberglass and Composite Boat Building 1 06-14-2009 02:40 AM
can i make a mould this way? oops! Fiberglass and Composite Boat Building 11 12-17-2007 03:32 PM
Balsa core vs. foam core James Maldonado Fiberglass and Composite Boat Building 23 01-21-2006 10:12 PM
need help for mould preservation mechatics Fiberglass and Composite Boat Building 3 04-01-2005 09:56 AM
