Old 05-13-2008, 07:45 AM
Bentwood Bentwood is offline
Bentwood
Rep: 10 Posts: 21
core-cell for deck
I notice many custom builders are using core-cell for decks and superstructures. I am building a 32' sailboat. The design calls for 2 layers of 1/4" ply covered by 6 oz glass. I am looking for suggestions about substituting core-cell for the plywood, particularly the thickness of the core and the fiberglass layup. Any technical references would also be appreciated.
Old 05-13-2008, 10:39 AM
Edmundo Souto Edmundo Souto is offline
Rep: 37 Posts: 12
1/2" foam with one 18 oz on each side is more than enough for your deck
Old 05-13-2008, 11:29 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Layers come out stiffer since the one layer has to stretch around the other. If you're set on using the ply then layer them on top of one another with a couple of layers (say 5 -6 layers of 400g/m^2 mat) in between (wet), stack some weight on it and allow 24 hrs for it to cure. If you can repeat this and add another layer it would be even better. Then work the outside. If there are large unsupported areas where the deck has to span with no support underneath I would seriously consider cross sections (ribs).
There is no such thing as a too strong deck. I always add the extra bit for that out of the ordinary situation. If thickness and weight is not an issue I'd say rather the overkill than the get killed.
Regards
Fanie
Water ! Just gimme water !
Foam Core - Deck, Cabin, Bulkheads SeaJay Fiberglass and Composite Boat Building 18 08-28-2007 09:15 PM
Optimizing core/skin thicknesses......for a deck Roly Fiberglass and Composite Boat Building 6 12-08-2006 01:39 PM
PU foam VS Core-Cell or other? Danielsan Fiberglass and Composite Boat Building 18 07-17-2006 07:42 PM
core-cell deck fabrication dolsen Boat Design 2 06-20-2006 06:50 AM
Core cell or Balsa?? SOB Fiberglass and Composite Boat Building 5 01-10-2005 12:51 PM
