| Coosa vs Nidacore I am refurbishing the interior of a 1975 Chris 33 Coho. The interior is gutted down to the hull. I am planning on replacing the plywood floor joist with fiberglass I beams on 24" centers. (to give me more headroom) What would the better product be for the decking? Coosa or Nidacore. My original thought was 3/4 or 1" Coosa. I talked to Coosa but have not talked to anyone at Nidacore Thank You Bob |
| I think that Coosa is a substitute for plywood, no re-engineering of details or fasteners as it holds a screw. Half the weight, twice the strength of plywood, but depending on where you get it, also twice the price. Honeycomb material will have you re-examining every connection and fastener, not sure you want to get into that here. Some details of how it is being secured might help you make a sound decision.
__________________ George: Architect (land lover type) Hovercraft & Vintage Porsche Owner http://www.boatdesign.net/forums/boa...ect-11973.html |
I would use Coosa ! end of story !! Have done quite a bit of work with nida and was not impressed with it at all . How do you intend to make the floor panel?? Glass both side ? but what glass are you going to use ??and how do you intend to make it ![]() |
| Thank You very much I am just learning how to work with fiberglass, not sure of anything at the moment. Would greatly appriciate some direction. I plan to seal all edges of the coosa then paint the topside. Wasn't planning on glassing - is that required. I have not seen coosa board yet. On top of the board will be carpet 4" Fiberglass I beam is replacing the 10" deck joist to give me more headroom, then the coosa will rest on the I beam Bob |
| Have you seen coosa board ? do you understand what it is ??HAVE YOU READ ANYTHING ABOUT IT ?? YOU HAD BETTER DO SOME HOME WORK REALLY QUICKLY !! ![]() |
| I know it is closed cell foam, cross thread fiber and roving. Not UV protected. 3/4 bluewater 26 is what I was going to use instead of 3/4 plywood. All I know is to seal the cut edges. I intend to secure the flooring to the fiberglass I beam with 3m 5200. Am I on track? Thank You Bob |
| I know it is closed cell foam, cross thread fiber and roving. Not UV protected. 3/4 bluewater 26 is what I was going to use instead of 3/4 plywood. Oh dear me Its a sheet of glass reinforced Foam !!!!It needs to be glassed each side !!! ![]() |
none of them! Both are insufficient without a strong panel backing both sides. This could be a GRP layup. But the cheaper way would be marine ply! When encapsulated in Epoxy and painted, it would give another 30 or so, years of service life. The argument that it can rot (when not proper executed) is as valid (itīs even worse) for any foam core. Regards Richard |
| Please be patient - I am by no means a boat builder I am confused - Coosa has told me the 3/4 BW 26 could be used directly as decking (flooring). I want to get away from marine ply due to weight. TUNNELS you stated you were "going" to use coosa - does that mean you have changed your mind or it is what your are planning to use. Bob Are you saying coosa is not as strong as I have been told? |
Nida is just foam, too weak to be used unsupported by glass both sides (all sides to be correct). In both cases you MIGHT end up a tiny bit lighter than with ply, but at about twice the cost and a higher risk of failure over the years. Regards Richard |
| I've used plywood, Nida-Core and balsa cored panels for flooring throughout my catamarans. Plywood is relatively inexpensive but it must be sealed against moisture. Nida-Core flexes more than balsa and large spans (18"-24") resonate annoyingly. Balsa is lightweight, stiff and attenuates sound well. It must be sealed to prevent moisture intrusion. I recommend 3/4" thickness for unsupported spans <18" and 1" thickness for 18-26" spans, regardless of material choice. |
| thank you very much. I plan to reduce the joist span from 24" to 16" CL. 3/4 coosa BW 26 for the flooring. Bob |
and still you would have to encapsulate the coosa in EP! Again, ply would be cheaper, almost as rigid, and less trouble >>>when completely encapsulated in Epoxy<<< Leave the so named advanced materials! The profit on them is advanced. The homebuilder / restorer has not a big advantage (usually the opposite) using that stuff. Regards Richard |
| I must agree that, unless you're building an ultra-light-weight vessel from-scratch, exotic materials (like Nida-Core, Baltek and Coosa) are expensive overkill. Just seal the marine plywood with resin and apply the savings to your beer-and-pizza fund. |
| Anyone have experience with NidaCore Polypropylene Honeycomb? | robherc | Materials | 21 | 01-17-2009 03:36 PM |
| nidacore - in jamestown | rapscallion | Materials | 0 | 08-11-2008 09:12 PM |
| NidaCore Pourable Transom Compound | dberr | Fiberglass and Composite Boat Building | 0 | 06-20-2007 05:24 PM |
| Converting plywood scantlings to Coosa/Nidacore? | YankeeBoater | Materials | 4 | 01-04-2007 01:59 PM |
| Info on Nidacore | Spud | Fiberglass and Composite Boat Building | 18 | 05-18-2006 06:33 PM |
