| Construction question Posted - Oct 15 2006 : 08:32:38 -------------------------------------------------------------------------------- I removed the lower half of the outer skin of my transom to fix the rot from leaking trim tabs.When I opened it up, I found not solid plywood, but, 4 inch squares of plywood, all butted together. Why do they do this? Isn't solid plywood stronger? How should it be replaced? My initial plan was to coat plywood w/ epoxy, then epoxy it in. Followed by epoxying the skin back on.Thanks. 1987 35' Luhrs Alura 35.
__________________ Fire Escape -1987 Luhrs Alura 35. Twin Crusader 454 model 350, MPI, 1.91:1 VD 1969 Thunderbird Formula 23', sadly sold. |
| I was wondering ,if you could replace plywood with composites ,,in sheets like plywood? |
| it shouldnt be in the transom, the squares are a poor mans coring. The theory is the resin between the squares provides strength.
__________________ Can anyone spare any gas today for a hamburger on Friday ??? |
| I talked with a guy with a small boat shop that makes his soles like this but leaves a space between the squares rather than butting them together. His theory was to control/contain rot if any occured to small areas. |
| go with coosaboard its all i use |
| Hull Construction | Nic Taylor | Boat Design | 11 | 05-25-2006 02:48 AM |
| Question about boat construction | Javi | Fiberglass and Composite Boat Building | 6 | 05-18-2006 02:00 PM |
| Question on transom construction | vixxen | Materials | 3 | 12-31-2005 01:58 AM |
| which construction method? | mjpetersen68 | Boatbuilding | 12 | 09-26-2005 03:48 PM |
| Construction | Nomad | Option One | 27 | 07-07-2002 04:34 PM |
