Old 02-26-2005, 11:20 AM
Hypercat Hypercat is offline
Rep: 10 Posts: 10
Composite Construction Software
Is there software where one can calculate strengths of composite materials and cored construction? I know result vary on methode of construction but I need approximate values anyways. Thanks.
Old 02-26-2005, 01:52 PM
Eric Sponberg's Avatar
Rep: 2464 Posts: 1,381
Actually, there are various packages of software that might work, but you really have to know a bit about composite engineering and composite fracture mechanics to use them. The engineering of composites gets into non-linear cross-linking in the three orthongonal directions which gets into some pretty complicated matrix alegbra. Then, of course, you have to make assumptions on the direction of the load, which is not always in line with the orientation of the fibers. Finally, you have to depend on reliable data for the fabric properties going in, and many times this is incomplete. One of the most critical inputs to most programs, shear modulus, is one of the least tested for in composite engineering--it simply is not available nor published most of the time.
Having said all that, I will defer to others who may have some respectable programs. I have a program that I wrote for my own use, it is a DOS based program. It works OK, but has not really been tested enough for use by the general public. Others have produced better programs I am sure. Just remember that they will be more complicated to use than you may expect.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 03-21-2005, 12:57 AM
dionysis dionysis is offline
Rep: 44 Posts: 256
Try the laminator, just as a start. (http://tni.net/~mlindell/Laminator.html)
Old 03-22-2005, 03:05 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Jim Antrim sells a program called PBJ. you can find him at 510-223-9680
Yokebutt.
Naval Architects Dubai chrisalex Services & Employment 25 03-28-2007 09:36 PM
Composite Software Armada Software 1 09-26-2005 12:59 PM
looking for good instructional manual on composite construction ocpaddler Fiberglass and Composite Boat Building 2 06-14-2005 05:21 PM
Is this progress in composite construction? Mark Peiffer Fiberglass and Composite Boat Building 16 01-13-2005 12:35 PM
boat construction software combine with TC Benny Brogan Software 0 04-19-2004 09:38 PM
