Old 06-06-2009, 09:38 AM
mikereed100 mikereed100 is offline
Rep: 10 Posts: 56
Composite Chainplates
I am planning some composite chainplates for my cat and am wondering what would be the best reinforcement? Is carbon really much more preferable to S-glass? From what I recall their tensile strengths are very similar. Carbon is stiffer but this would not be much of a plus in a chainplate where nearly all the load would be linear.
Any thoughts on this and composite chainplates in general would be greatly appreciated. There is precious little on the web apart from this link to a most excellent site:
Composite chainplates
Thanks,
Mike
Old 06-06-2009, 09:47 AM
Ad Hoc Ad Hoc is online now
Naval Architect
Rep: 489 Posts: 1,637
It is not so much the chain plates, rather than the how are the chain plates "attached" to the hull. If you haven't analysed the loads correctly, you will get interlaminar shear failure very quickly, owing to underestimating the loads and not establishing the load paths, and hence, the resins/lay-up required to transmit said loads.
Old 06-06-2009, 01:06 PM
jmolan jmolan is offline
Rep: 30 Posts: 36
Mike, see ifyou can send a PM to Gashmore, I know I saw he has already done chainplates like you are talking about.
Gashmore
Junior Member Join Date: Feb 2008
Rep: 32 Posts: 17
To late for the chain plates. They are carbon composite integrated into the topsides and deck. I didn't want to worry about leaks.
Old 06-08-2009, 09:33 AM
AndrewK AndrewK is offline
Rep: 40 Posts: 102
Mike,
E-glass, S-glass, CF will do the job. decision comes down to what you are willing to pay to save a bit of weight. Relative to E-glass CF will save approx 40% wt, S-glass only about 15 - 20%. Get advice from a composite engineer, as AdHoc said its important to spread the load into the hull structure and to use high shear cores in this area.
As a guide local builders are using a UD lay up that has a SF of 5-7 times the wire breaking load.
Depending on the resin you are using the shear strength could be between 20 - 40MPa so important to calculate the correct surface area required.
You can position the chain plate on the hull side or on a bulkhead. I have seen the UD strapping applied in two ways.
1. Stainless tube is glued on top of a panel at the same angle as the shroud and a slot is cut at the appropriate distance down from this tube that is exactly parallel and aligned with the tube, this distance will be approx 600mm. Continuous 100mm wide UD tape is then simply wound around the tube and the slot, the fibers remain parallel with this method ie you do not splay out the bottom.
2. Alternative is to use pre cut lengths of UD tape and lay these at +/-6 degrees across the tube. This fanning out of the tapes will increase the contact surface area and be more forgiving with the alignment. There is some DB also interlayed amongst the UD.
Let me know if you want more details and photos how I did mine.
Andrew
Old 06-08-2009, 09:37 AM
Naval Architect
mike
You may be lucky, but the values that AndrewK gave for shear strengths may be just data sheet stuff. (Can you confirm this AndrewK, or are these from actual coupon tests of your own layups?).
I would use a value of 15MPa for interlaminar shear for a basic Glass layup.
PS
Not exactly the same, but I just recently finished a job analysing at the loads from a lifting eye, to lift the whole boat; a steel plate bonded into a Glass layup. No matter how you look at it, 15MPa was about as high as i would go, without any real coupon tests for shear.
Old 06-08-2009, 05:37 PM
Rep: 10 Posts: 56
Thanks to all for the replies. This info is pure gold. I did a quick calculation using 15MPa sheer strength and 7x the rigging wire breaking strength of 33,000lbs (This is 14mm wire on a 46’ cat). Comes out to 106 sq in which is actually less than I was planning. The load is parallel to the hull.
Andrew,
Thanks for the suggestions. I had not considered either of the build methods you describe but they both sound better than what I had planned. I would love to see pictures and details of what you have done and would gratefully welcome any additional comments.
Thanks again,
Mike
Old 06-08-2009, 06:06 PM
CTMD's Avatar
CTMD CTMD is offline
Naval Architect
Rep: 109 Posts: 185
Mike,
check PMs
Chris Tucker Marine Design
Your Boat Your Way.
www.ctmd.com.au
Old 06-09-2009, 09:56 AM
Rep: 40 Posts: 102
Ad Hoc, the resin shear values I mentioned is from data sheet and not test results for my laminate.
I would like to see data showing the difference between test results and calculated values if anyone would like to share these.
Mike
For option 1, I forgot to mention but as the tape is wound around a section of a panel you get the benefit of mechanically locking into this panel as well.
If you look at the photo in Masalai's thread My little piece of peace, you will see the start of this process.
Personally instead of trying to feed the UD through this slot I would extend the cut out to the edge so that the tape can be simply slotted in and not having to poke it through the slit. This way you can cut the length of tape required wet it out roll it up on to a tube and then wind on to the job.
For the stainless tube you have an option to keep it in one piece or cut into 3 segments, two 50mm segments either side of a small segment which is dimensioned from the gap in the toggle of your rigging screw. These segments are separated with plastic discs say 5mm to suit the toggle thickness. This assembly is held together with a bolt, I used this method and you can see this in one of the photos. Advantage with the segmented approach is that you do not have to cut through the laminate later, you simply knock out the discs.
My chain plates are located on the hull so I used approach #2 as I preferred it for this purpose. You will also see that I used a balsa insert 600 x 900mm in this area for its high shear value, 200kg foam was out of stock at the time. Chain plate is located between a bulkhead and aft edge of the dagger board case, distance between the two is 1300mm, laminate in either side in this area was doubled.
The UD tapes were layed at +/- 6 deg across the tube ranging from 900mm either side down to 300mm. There were 3 layers of 450g DB glass interlayered amongst the UD, each one covering the foot print of the UD plus 50mm more than the previous. Finally there was a 560g triaxial and 450g DB covering the area a bit larger than the balsa.
Internally between the two bulkheads there will be pigeon hole lockers that will also help spread the load.
Andrew
ID:	32319  composite-chainplates-p1010512-1-.jpg.JPG
ID:	32320  composite-chainplates-im000002-1-.jpg.JPG
Old 06-09-2009, 07:20 PM
Naval Architect
Hi Andrew
When i don't have actual coupon tests for design values i use this:
Interlaminar Shear = 22.5-17.5Gc MPa
Where Gc = 2.56/ [(3072T/W) + 1.36]
T = nominal laminate thickness, mm
W = total weight of glass in g/m^2.
This is from a very good ref book I have, based upon actual tests of various different layups and all tested.
So, it is iterative.
When i use my own old in-house tests data (of various lay ups, thickness etc etc), and select a layup and hence its tested shear value, it comes out very close. So i now always use this formula.
Old 06-09-2009, 09:59 PM
Naval Architect
Andrew
BTW..how is the boat progressing?
Did you sort out your calculations too?
Old 06-10-2009, 08:21 AM
Rep: 40 Posts: 102
Hi Ad Hoc,
Using your formula for ILS a standard hand laminate with 50%wt glass ILS=14MPa and infused laminate at 70%wt glass =10MPa.
This is a long way short of 20 - 40MPa I have seen on data sheets for epoxy resin systems. I can see how hand laminates can vary from shed to lab, but infused laminates should be the same.
Surly the 22.5 can not be a constant for all types of resin and cure conditions?
I would have expected something more like say ILS corrected= data sheet ILS - 17.5*Gc
Boat progress has been very slow, just had three weeks of very wet and humid weather.
And now that the rain has stopped over night temperatures have crashed down to6-8'C.
Have not finished the calculations, I will send you what I have done so far.
Chears
Andrew
Old 06-10-2009, 09:49 AM
Naval Architect
Andrew
sorry I should have noted that the values are for basic E-Glass lay ups like CSM/WR, not epoxy.
Old 06-10-2009, 11:34 AM
Rep: 10 Posts: 56
Thanks Andrew, that's very helpfull stuff. What are you buillding?
Mike
Old 06-12-2009, 09:57 AM
Rep: 40 Posts: 102
Mike, my boat is a 11.9m foam cruising catamaran.
Are you locating your chainplates on the hull side too? which way are you leaning CF or glass?
Old 06-12-2009, 01:35 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 20 Posts: 157
Andrew, lets see more pix of this boat project of yours. I for one would love to check it out.
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Internal or external chainplates? San Juan Sailor Fiberglass and Composite Boat Building 3 03-24-2009 08:10 PM
Composite chainplates tbot Fiberglass and Composite Boat Building 15 08-07-2008 09:45 PM
alloy chainplates gramos Boat Design 5 04-22-2008 12:00 AM
glassing in chainplates bluwateronly Sailboats 13 02-11-2008 01:50 PM
chainplates Lunde Wooden Boat Building and Restoration 0 10-08-2005 02:02 PM
