| Completely re-doing a 12 foot Jon Boat lots of ??? First boat, and needs LOTS OF WORK. It's an old 12 foot Sears Jon Boat, made out of ABS plastic. Has lots of little Cracks and chips and one nickel sized hole. Got it and trailer for some yard work. I can do the trailer no problem, I'm good with my hands. But, with the plastic being cracked, should it be chipped off and start over with fiberglass? or should the fiberglass be applied and worked with of course over top of the cracked plastic? Lots of prep of course. I can do any automotive body work, but I'm clueless when it comes to boats. funny. I looking to completely overhaul this boat. Patching is not an option. |
| The bad news is that if its plastic (not fiberglass) then its most likely not ABS, more like polyethylene, which is very difficult to repair. If there are cracks all over and holes in it, its pretty much done for. Things will stick to ABS, but like other plastics, if its aged and weathered to the point of cracking, then there's no hope for it. |
| Possibly not. But it's worth a try. I'm thinking about pressure washing the current plastic, sanding it then Fiber glassing over the plastic. sand and paint. Then Clear coat possibly. I realize that gel coat would probably be better but trying to keep a slight budget here. Then for the inside, level and carpet. Re do the seats, add battery, interior lights, exterior lights, and reinforce the transom for a 15 horse out board. Then add a trolley motor. It will be one bad azz boat. Even though the skeleton ain't the best, it'll do for my first boat, and boat project. |
| Can you post a pic so we can see which Sears boat it is, they made many models from many different materials. |
| Many plastics can be welded. Might be worth to check out.
__________________ Hopefully creating something useful, since 1983. |
| Yeah I'll post a pic when I get to the house. |
| here are some pics little rough now, and a lot of work ahead of me. But It's something to do to keep me out of trouble. I know it probably ain't worth it. |
| That's a good looking boat you've got there. ![]() L
| Quote "Many plastics can be welded. Might be worth to check out." True, the difference is that fresh plastic in good shape can be welded and if done correctly may hold up. The problem is that aged plastic cracks because it has been weakened, typically from UV exposure, when this happens no amount of welding will help or hold up. |
| New Member with lots of ??? Help ID boat | EndlessSummer | Powerboats | 12 | 01-16-2010 02:01 AM |
| Lots of questions! My first boat design, again... | garrick | Boat Design | 10 | 02-05-2009 02:12 PM |
| first marinizing of my boat lots of questions | dumbjarhead | Open Discussion: All Things Boats & Boating | 12 | 01-05-2007 07:38 PM |
| First time alum boat builder with lots of questions. | Bob boat bldr | Metal Boat Building | 5 | 11-14-2006 09:28 AM |
| Completely amateur >70cm RC boat | Boat Design | 1 | 09-14-2001 08:36 AM | |
