Old 10-25-2006, 03:01 AM
Roly Roly is offline
Rep: 222 Posts: 471
Compatibility......foam core & sheathed edge glued
Can you put a foam cored deck/cockpit/coachroof on a strip planked fully sheathed hull (exterior & interior), or is there a problem with the inherent stiffness difference of the two systems?
Old 10-25-2006, 02:03 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Yes.
Yoke.
Which Foam for Core? Toby P Fiberglass and Composite Boat Building 5 05-06-2006 06:44 PM
Balsa core vs. foam core James Maldonado Fiberglass and Composite Boat Building 23 01-21-2006 11:12 PM
Selecting foam core TomE Materials 14 01-07-2006 05:18 AM
Composite replacement of a edge glued strip planker Roly Fiberglass and Composite Boat Building 18 10-15-2005 12:56 AM
Foam core Hotrod99 Fiberglass and Composite Boat Building 9 09-06-2005 02:24 PM
