Old 06-17-2007, 09:29 AM
Buckie Buckie is offline
Rep: 10 Posts: 24
Cold/Hot flow Gelcoat !
Hi guy's I'd like to know if I had a compleat mould (top & bottom) seald closed could I just drop in a big blob of gelcoat and rotate the mould so the gelcoat spreads itself through out the mould.
Also what happens if you heat gelcoat before aplication ?
cheer's guy's
Buckie
Old 06-17-2007, 09:47 AM
JRL JRL is offline
Im with stupid
Rep: 25 Posts: 83
Really not sure if it would work. Only one way to find out though.
If you heat the gel just keep in mind that for every ten dergees increase in temp your cure time will half.
Old 06-17-2007, 10:04 AM
Rep: 10 Posts: 24
I'm just thinking out loud really, just a lazy way of mass production. Once the gel had cured the entrance would be opened and allow access for the glassing to be done, a sort of all-in-one boat. with most of the work being done while in the mould. (you know get the small children from the local school to work 4 hours after school, inside the mould) LOL
Buckie
Old 06-17-2007, 02:14 PM
hmattos hmattos is offline
Rep: 59 Posts: 115
If it helps, we do make consoles for our RIBs in a rotatable mould. However we still can sit inside to gel coat as gel will not spread well - that is why it is called gel!!!
It does help however to rotate the mould during layup by hand to redue pooling of resin, however it is a very practised art since too much resin leads to the top lamiate falling off before it is set, and too little leads to dry spots.
Temperature is really critical to all GRP layup, as we find with our products they are completely unspreadable at 14 degree Centigrade, great at 17 deg but set too fast at 22 degrees.
Have a look at the website:
www.explorermarine.co.uk for pictures of what we make
Regards
Hugh Mattos
Old 06-18-2007, 03:13 AM
Rep: 10 Posts: 24
Vey nice and interesting too.....If I go ahead it would be a 36' cruiser all-in-one, mainly to be water tight to withstand any type of weather, I'm also looking at a zink alloy mould to look at the possibility of a hot plastic outer rather than a gelcoat. I've looked at an Acrylic 10 mm sheet but can't get a sheet large enough, I'd have to make it myself. (you know like a glass reinforced bath) Its just the investment that's stopping me at the moment. I have enough to go a head and build GRP Boats but I wanted to do something different. I've searched all over to try nd find the name of the plastic thats used for the little red boats childrenn use in the bath as they are indistructable and would prove a great material to work with.
thanks for the info.....
Buckie
Old 06-18-2007, 03:22 AM
Rep: 59 Posts: 115
Remember also that the fumes from GRP layup are pretty noxious, so working in a closed mould will be very dangerous.
For 36 foot boats most of the industry are moving to Resin Transfer Moulding or RTM Light in two sided moulds or vacuum bags.
It is a much easier process to bond two halves, than to make a single piece integral boat.
Good luck
Hugh Mattos Chartered Engineer
Old 06-18-2007, 12:49 PM
JRL JRL is offline
Im with stupid
Rep: 25 Posts: 83
Good luck
RTM Lite is pretty cool. Almost cheap enough to do at home.
Old 07-27-2007, 11:47 PM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
how would you know how thick it is?, and i would think you need to keep it spinning till the gel-coat kicked off
Old 07-28-2007, 03:31 AM
Rep: 59 Posts: 115
Gel coat thickness is measured with a simple gel coat gauge - until the applicant is experienced enough to " know " how thick it is.
Gel is a thixotropic liquid, so spinning it to fast will result in all the gel being at the keel and cabin roof!
Have a read of IBI News, which regularly reviews manufacturing practice around the world and has never discussed rotary moulding. That is normally reserved for polypropelene kayaks and oil tanks and storage drums.
Good Luck
Old 08-07-2007, 08:26 PM
jammer's Avatar
jammer jammer is offline
Old, bald and ugly
Rep: 10 Posts: 44
Buckie,
You mentioned earlier about acrylic, have you considered HDPE? It's weldable to any size sheet you need. Boulder Boat Works make their small boats that way.
Dave
I am...therefore I must learn
Old 08-07-2007, 08:53 PM
the1much's Avatar
huh? hehe ;)
Good Luck
yes i, we should know about a gauge, heh, what i meant was, how ya gonna stick ya arm in there while its spinning,and what kind of mark will the thickness gauge ( scraper lol) gonna leave. and if it was a half complicated part, wouldnt ya have to spin it in 2 directions or more to get it in the hard to reach areas evenly
Hot Tub In A Boat rhubley Boat Design 26 05-03-2007 04:37 PM
Outlet flow velocity luitxi Boat Design 2 10-25-2006 04:50 AM
Engine too hot seagums Gas Engines 5 08-09-2006 01:02 AM
Water Flow Poida Powerboats 3 05-01-2006 10:06 AM
Pipe-flow propulsion?? SanSan Boat Design 0 08-28-2005 07:37 PM
