Old 04-02-2005, 08:03 PM
drs3317 drs3317 is offline
Rep: 10 Posts: 47
COCKPIT Floor HATCH
Cockpit hatch
I'm rebuilding the cockpit floor in a 31' sedan I recently bought. It had been neglected and most of the supports were rotted or missing. I have the support structure all planned and the materials ready for the sole. The total area is 10'x6'. I need to install a hatch in the middle.
My question. How do I seal the floor around the Hatch which will be 2'x4' ? I have noticed on newer fiberglass boats they use an aluminum channel around the hatch so the water runs aft and then overboard. Using marine plywood I'm not sure.
Thanks
Old 04-03-2005, 08:27 PM
gonzo gonzo is online now
Rep: 1397 Posts: 7,215
You should be able to build the same system with plywood. Aluminum is easier to make a chanel of than wood.
Cockpit Canopies on Walkaround Willallison Powerboats 19 07-01-2010 09:10 PM
air conditioned cockpit on flats or bay boat Tarpon1 Boat Design 13 12-01-2005 11:23 AM
cockpit or pilothouse EASI54 Boat Design 17 09-05-2005 06:23 PM
Self-draining cockpit sdroberts Boat Design 0 08-30-2005 07:03 AM
Seif bailing cockpit? duluthboats Boat Design 2 02-19-2004 02:30 PM
