Old 01-23-2012, 08:04 AM
Frosty's Avatar
Frosty Frosty is online now
Rep: 1693 Posts: 5,866
Cobalt in resin.
What is cobalt ? Im encouraged to use it by my little resin shop . I think he is telling me to use it to make it harder and not tacky. He suggests a tiny amount.
What is it and do you use it.
Old 01-23-2012, 08:14 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
http://en.wikipedia.org/wiki/Cobalt
Be careful! Toxic!
Hoyt
Old 01-23-2012, 08:20 AM
Frosty's Avatar
Originally Posted by hoytedow View Post
Really ? this was on your link.
Cobalt is the active center of coenzymes called cobalamins, the most common example of which is vitamin B12. As such it is an essential trace dietary mineral for all animals.
It is also used in beer--it goes on to say.
Nothing however on using it in Polyester resin!!
Old 01-23-2012, 09:08 AM
hoytedow's Avatar
Resistor
http://www.omgi.com/product-adv-resin.html
Hoyt
Old 01-23-2012, 09:09 AM
hoytedow's Avatar
Resistor
http://www.osha.gov/SLTC/healthguide...cognition.html
Hoyt
Old 01-23-2012, 01:18 PM
pauloman pauloman is online now
Rep: 65 Posts: 55
see the page www.epoxyproducts.com/enamel.html
paul
Old 01-23-2012, 02:29 PM
dinoa's Avatar
dinoa dinoa is offline
Rep: 61 Posts: 70
Cobalt napthanate is often used to accelerate the curing of polyester and vinyl ester resins.
Dino
Old 01-23-2012, 07:52 PM
Frosty's Avatar
Is it necessary ?--what if it is not used? is there a particular application where it has to be used.
What is the benefit of using it for a small user like me on DIY projects where I will mix nothing more than a coffee cup at a time.
Old 01-23-2012, 08:09 PM
FMS FMS is offline
Rep: 125 Posts: 233
I wouldn't DIY resin. Buy it off the shelf promoted or have it mixed to your spec.
(ask) Resin Properties
Be careful if you store or mix in cobalt yourself
Cobalt Accelerator
Old 01-23-2012, 08:24 PM
Frosty's Avatar
Have it mixed to my specifications? I only buy a liter at a time at the hardware shop. In Malaysia they dont know what it is -In Thailand they sell it to you everytime in a tiny plastic bag along with a similar packaged hardener.
I am told-- a small drop is sufficient for a coffee cup full 0.1%,- the hardener at 1 %, I am following the instructions successfully but have no idea why
In the temps I am working in you only need to wave the hardener over the resin and it will go off.
Old 01-24-2012, 03:58 AM
Silver Raven Silver Raven is offline
Rep: 39 Posts: 173
The use of 'Cobalt'
'To 'Cobalt' or or Not to Cobalt - that is what ?.
With all 'polyester resins' - what is called 'catalyst' is just that - a substance that increases the rate of a chemical reaction without itself suffering any permanent chemical change - dictionary. Catalyst can come in several different strengths. Catalyst 'starts' the action of the resin going hard - roughly speaking - Cobalt - will - accelerate that action.
Ideally speaking - you don't want the resin to 'gel' before it has had time to - wet out all the fibers of the reimforcement being used. THIS IS VERY IMPORTANT As your are well aware - least is best - everywhere in the tropics (hell man - I've only lived here in Cairns for 30 years or so) - been in the FRP industry - building yachts - since '54. Try to keep catalyst somewhere above 1/2% if possible - best is 1% - (MUST be mixed in very well - for obtaining the best results) then if you need to shorten the 'gel' time use 1/16 - 1/8 or so % cobalt - - VERY very little - use a little eye-dropper - is the go.
You may wish to refer to - "masalai's comment" - from SEQ - OZ - 'post' #4344 - 23rd jan - 1654 hrs - "Your helper might be able t" - - if that doesn't work try me - PM - not anything personal!! HE he he he he. Ciao, james
I really wish I was up ther to help - just to show - my thanks for your info about the place - but t'ther's to many bloody Aussies here already' hey!!
Do PM me if you get in bother. Ciao, james
Old 01-24-2012, 02:04 PM
keith66 keith66 is offline
Rep: 117 Posts: 223
Cobalt accelerator is added to resin to allow the catalyst to set the stuff.
Most resin in the UK is now supplied pre accelerated so you dont have have to add it yourself. This is a very good thing as, a) its toxic & b) if accelerator comes into direct contact with peroxide catalyst there is a violent reaction that is liable to be explosive.
I remember at Thames marine years ago when someone put Catalyst in a Cobalt dispenser by mistake it reacted & he threw the dispenser, it went of with a large bang & left some interesting stains on the walls. Fortunately no splashes in anyones eyes.
Only normal use would be to add more to aid setting in very cold conditions.
In Thailand i wouldnt see any use for it at all unless the resin is supplied un accelerated, which may be the case to extend shelf life?
Old 01-24-2012, 07:44 PM
Frosty's Avatar
Thanks Silver and Kieth that just about hits the nail on the head, I understand now what it is.
I think Thailand must supply un accelerated because one shop said it was already mixed in, he does it himself after de canting from a 50 gall drum into water bottle type containers for small 1 kilo purchases.
I might as well drop a bit in now ive got it.
Old 01-25-2012, 04:49 AM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
Some types of resins (VE and filled resins) are commonly supplied unpromoted because they tend to have poor stability and the shelf life is fairly short. And in some parts of the world it's more common for them to come unpromoted because this gives the end user more adjustability when there are fewer resin choices, it also extends the shelf life in hot regions or where usage may be slow.
In the US and some other parts of the world if you want a 12 minute gel time you can buy it, or maybe 15, 20, 25, or 35 minute, they can be found easily. But if the demand for product doesn’t justify stocking all these different gel times, the distributor may stock an unpromoted version, or the 35 minute product and have the fabricator add a small amount of cobalt and/or DMA to speed it up if needed.
Cobalt will affect the gel time and DMA will have more of an affect on the gel to peak (the time from when it gels to when it actually cures and becomes hard and reaches it’s highest temperature)
Old 01-29-2012, 09:50 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Cobalt !All the time i have worked with resins and glass early every company has Cobalt and use it for a few differant things. One company they used acetone and cobalt mixed to brush onto wood and let it soak in and then resin and glass over when using polyester and Vinylester resins . seemed to be ok ! dont know about the long term !!
When making surry , fillers and fairing always mix cobalt ! everything you add to resin slows it down so the cobalt will speed it back up , Like all things to do with resin dont go overboard and get carried away !!! add to much and you end up cooking things with the excess heat thats produced . Heat = shrinkage = pre release = distortion !!!
Moderation is the name of the game , specially for those that are newbies !.
CATALYST AND COBALT ARE INSTANT HEAT AND SMOKE AND FIRE !!!
SO be warned !! if you are working at home and at work keep COBALT AND CATALYST separatored like at differant ends of the building !!! . if you have never seen a fibreglass place burn you are in for a treat !! takes a little effort to get the resin started to burn but the heat is so intence and all you have time to do is run . the smoke and fumes will kill you !! also if working at home keep them away from and completely out of the reach of children of any age including mindless thoughtless teen ages !!
Making beautiful boats is a passion never a chore !
Cobalt Accelerator Butch .H Wooden Boat Building and Restoration 4 01-24-2012 05:22 AM
Restoring/Repurposing a 1979 Cobalt 18' Tri Hull Beedub Fiberglass and Composite Boat Building 1 11-10-2011 08:36 PM
Cobalt anyone?! Rupes Software 1 12-04-2004 04:47 PM
Shelf life of Cobalt-12% ??? Glenn Shotwell Materials 2 08-21-2004 10:51 PM
Cobalt nemo Software 4 03-13-2003 01:02 PM
