Old 10-19-2008, 05:54 PM
Sam III Sam III is offline
Rep: 46 Posts: 71
CNC cutting Fiberglass cloth
Does anyone here use a CNC machine to cut fiberglass cloth for boats?
I would like to do that for a boat we are building but am not sure what kind of equipment it takes?
Heaviest cloth we use now is 600 gsm Triax fiberglass and 600 gsm Carbon fiber.
I have a CNC Router and was thinking of locating/building a rotary cutter attachment to cut the material.
Thoughts, hints, experiences?
Thanks in advance.
Sam
Old 10-21-2008, 03:24 AM
Nick F Nick F is offline
Rep: 10 Posts: 19
Sorry ne experance to date but this is interesting.
http://nz.youtube.com/watch?v=bHeKgs058Lc
Nick
Old 10-21-2008, 06:28 PM
CTMD's Avatar
CTMD CTMD is offline
Naval Architect
Rep: 117 Posts: 196
The video gives a good idea of what is required. I'd be surprised if your router could be tailored to suit. As you can see on the video, the blade has to be rotated to suit the cutting direction, this isn't typically available with CNC routers, but talk to the manufacturer, you never know.
Chris Tucker Marine Design
Your Boat Your Way.
www.ctmd.com.au
Old 10-22-2008, 03:33 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1943 Posts: 4,195
Hi Sam
You can lasercut fiberglass. The cutting line is black though, since the glass gets burned away there. You will need a bit more laser power than you expect, which is stil relative low... 60 W up could probably cut it. Speed may be slow on the lower watts.
I don't know about the carbon fiber, haven't found out about that though.
Most CNC softwares have the option to compensate for backlash on the axles. If you have a rolling blade that 'drags' behind the X Y position, you should be able to compensate for that.
On the other hand, it won't be a boat smash to add a 4th axle to steer the rolling blade in the direction it is cutting..
Regards
Fanie
Water ! Just gimme water !
Old 10-22-2008, 03:58 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
Maybe these guys can help, they have been cutting fabric with CNC for a long time.
http://www.carlsondesign.com/#Plotter_Cutters
"The hand feeds the mind."
Weston Farmer
Old 10-22-2008, 04:35 PM
Fanie's Avatar
Fanie
Hey hey ! Check out the sail software down the page
Regards
Fanie
Old 10-23-2008, 06:18 PM
Rep: 46 Posts: 71
I emailed Greg last week but have not heard anything back yet.
I would need to add a 4th axis or have an off center rotary blade and then allow for lead in movement and blade offset on my cutting instruction.
IE drop the blade down close to material and move real slow on X Y to align the blade behind the center point of the router axis.
Sounds do able, but I subscribe to the 'Wisdom' vs 'Experience' School.
Experience you learn from your own mistakes. Wisdom you learn from others.
Sam
Old 10-22-2011, 07:05 AM
David White David White is offline
Rep: 10 Posts: 8
If anyone is still interesred, my company specilises in cnc machines for cutting difficult products.
If you go to our site at www.advancedrobotic.com and go to ROUTERS.
Pay special attention to the Smart Router XR4800. There are videos there cutting fibreglass among other things.
Old 10-23-2011, 08:53 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
Originally Posted by David White View Post
If anyone is still interesred......
Yup. I am "interesred"
Had trouble finding the videos - can you paste a more specific link please David ?
Old 10-24-2011, 01:46 AM
Rep: 10 Posts: 8
Videos for fibreglass mat cutting
Try these videos out to see fibreglass matting being cut using the Pizza Wheel attachment on the XR4800 Smart Router.
This tool automatically loads, along with straight and bevel knives, reciprocating saws, drills, and of course, router bits.
It cuts almost anything.
The first link is on our web site so you can see other features available if they are of any interest.
http://www.advancedrobotic.com/NdRNFqPfyN0-video.html
also
http://www.youtube.com/watch?v=vwJk_yZNEn4
http://www.youtube.com/watch?v=74EFu-FQzeM
http://www.youtube.com/watch?v=S-WQ1wdeFEY
Old 10-24-2011, 01:47 AM
Rep: 10 Posts: 8
Thanks for the spell check too!
Old 10-24-2011, 01:48 AM
Rep: 10 Posts: 8
We also have special matting for under the knife to stop damage to the cutters.
CNC foam cutting and software zerogara Boatbuilding 1 07-30-2010 12:33 PM
Sourcing for 20'ish ft boat plans and CNC cutting files. blacksheep Boat Design 16 07-13-2008 06:31 AM
CNC Plasma Cutting Services Lafitte Services & Employment 0 05-15-2007 09:20 PM
CNC cutting file....need to make one. MikeJohns Software 6 02-08-2006 10:40 AM
Wanted: CNC Router Cutting Service in San Antonio JEM Services & Employment 0 08-29-2004 09:58 AM
