Old 12-17-2005, 01:20 AM
Semloh Semloh is offline
Rep: 10 Posts: 5
cloth width in large panels
When making a large panel can you use two rolls side by side or do you have to find one wide enough to cover the whole panel?
If you can use two side by side how do you set them? One over lapping the other a certain amount or just butted up next the other?
Do you lose some strength this way?
Old 12-17-2005, 02:36 AM
Karsten Karsten is offline
Rep: 22 Posts: 146
You have to overlap the cloth. Otherwise how are the forces going to get acress the gap? The amount of overlap depends on the cloth and the shear strength of the resin. You have to work out the maximum force your cloth can transfer and then work out how much overlapping area you need so the resin can transfer this force in shear. There will also be some stress concentrations at the beginning and end of the bond. So you could carry out some extremely tricky calculations or just overlap 50mm (2 in). That's sort of the safe standard.
Old 12-17-2005, 09:41 AM
Rep: 10 Posts: 5
Thank You
Old 12-19-2005, 03:50 PM
Ssor Ssor is offline
Rep: 10 Posts: 174
Assuming that you are not building a single ply panel you can but the cloth in each ply and stagger your joints so that you over lap each joint with whole cloth. If you build with overlapped joints and fail to distribute them across the entire panel you will have a ridge down the middle that is twice as thick as the rest. You could easily alternate your layup so that the first layer was laid from left to right and the second layer was laid from top to bottom. You should always plan a layer of chopped strand mat between layers of woven cloth.
Old 12-19-2005, 05:40 PM
John ilett's Avatar
John ilett John ilett is offline
Rep: 23 Posts: 131
There also many glass fabrics which have a tapered edge specifically for overlaps so there is no excess thickness. Wide rolls are often 4ft/1.27m wide.
Old 12-25-2005, 02:41 PM
makeitfly makeitfly is offline
Rep: 10 Posts: 12
As mentioned 50mm is the minimum amount to do any overlap anywhere in hi stress situations it is 80mm to 100mm when using cloths and unidirectionals regurdless of what sort of resin you are using .
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 04:00 PM
Freeship plywood panels Deering Software 10 12-04-2005 01:42 PM
Unsightly Panels aitchem Metal Boat Building 3 12-01-2005 06:05 AM
Cruising Cat Width Inquisitor Boat Design 69 11-13-2005 12:31 PM
Fiberglass over Stainless steel panels mik lenoir Sailboats 10 10-26-2005 05:42 PM
