Old 10-20-2011, 09:00 PM
hyboats's Avatar
hyboats hyboats is offline
Rep: 10 Posts: 42
cloth print and ripple
when we take the deck out from mold the surface is very very smooth and shinning, no cloth print, no ripple. But about ten days later cloth print and ripple occurred, especially when deck is under sunshine. I think it is after cure but we don't how to slove this problem
the first layer is 50g/㎡ surface mat then two layers 350g/㎡ mat
--------Who can help me
thank you !
Bruce
Old 10-20-2011, 09:46 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
Dark colours accentuate the problem.
What 'goo' are you using ?
Old 10-21-2011, 01:34 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
thank you !
What is the patern you are getting?? csm or cloth print through ??
The ripples could be pre-release from the mould as it cures !! this could be dirrectly related the a surplus of resin left in the glass to cure . Pools and duddles etc etc
Glass floats if you have to much resin !!!
What you are exsperiancing sounds like resin shrinkage!, as it cures it draws and shrinks , some resins are worse than others also the type of catalyst you use can make the resin heat more , you need quick gel slow cure Catalyst ! .
Your surface matt is what exactly ??
is it Tissue ??
350 grams X 2 Is way to much glass for a first layer and its loaded with resin so this is where your shrinkage is coming from initally . if you want csm then use a 450 gram P matt ! must be P" matt !!
Do you understand the differance between P matt and E matt ?? !
All we use just a skinning tissue with 300 gram csm p mat and use Vinylester resin . By nature Vinylester has less shrinkage and goes harder than the polyester . NEEDS TO CURE ABOUT A GOOD 12 HOURS IF POSSIBLE then carry on making the boat !
What is the lay up schedual for the boat ?
Do you use woven glass OR stitched glass ??
As already mentioned colors have a lot to do with Shrinkage and draw from the sun !!
as well dark colors draw so much heat !!
light colors not so much !!
white is best but hard on the eyes or very light gray that in the bright sun looks white but is easyer on the eyes .
Another product you could look at is barrier coat !!.
Never used it myself so dont have any first hand exsperiance to pass on about it .
If it was me i would do tissue , 450csm with, vinylester resin ,check what catalyst to use with it !,let it gel and cure for 12 hours ,or more then build the boat . and see what you get !!.
Making beautiful boats is a passion never a chore !
Old 10-23-2011, 09:30 PM
old one !
Any chance of getting some pictures ?? Keep us informed how you get on !!and what you tried and what worked !!
I have been through all these issues a few times and its a process of elimination till you find what works for what you are doing and the materials you are using and how you are using them . as I said even a simple thing like changing catalyst can help solve the mystery !
I wrote a few pages for our managment in this company discribing the many causes and possible remedies !!
Old 10-26-2011, 07:57 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Indeed there is a tad too little info to give directions in which to move.
What materials do you use exactly, including gelcoat, peroxides, fabrics, and which time schedule is kept, including temperatures.
Do you happen to have a barcol meter?
cloth print and rippled effect hyboats Boatbuilding 2 10-19-2011 11:34 PM
glass print through ! tunnels Fiberglass and Composite Boat Building 16 02-06-2011 11:23 AM
Print through Carbonman Fiberglass and Composite Boat Building 0 08-08-2009 10:18 PM
Dark Shadow and Ripple of Light; Ball Lightning or My own Ghost Tale? kach22i Open Discussion: All Things Boats & Boating 18 03-24-2007 10:45 AM
Cloth over cloth, no mat Koz Materials 13 01-30-2006 05:18 PM
