Old 10-18-2009, 11:41 AM
pescaloco pescaloco is offline
Rep: 67 Posts: 243
Ok guys one last question please
I allready primed some spots with the Awl 545 I assume if Imron was used that one would still have to use the Imron primer ? or is it (Imron) compatible with the 545 primer coat.
THAAAAAAAAAAAAANKS !!
Old 10-18-2009, 04:17 PM
Rep: 1493 Posts: 7,447
Imron is pretty forgiving.
Old 10-19-2009, 11:19 PM
Rep: 527 Posts: 792
Imron topcoat is fine over 545; use it. Awl 545 is a better primer than any of DuPont's primers.
Jimbo
Old 10-20-2009, 10:06 AM
Rep: 67 Posts: 243
Thanks guys
Old 10-20-2009, 11:47 AM
missinginaction missinginaction is offline
Rep: 417 Posts: 336
I've been following along here trying to learn......
Jimbo, you refered to a technique called "guide coating". I've never heard this term. Based on the context I'm thinking that the technique refers to spraying a light coat of black over a lighter color. Once dry one would sand off the light black coat thus insuring that no spots were missed.
Am I on the right track here?
Thanks for posting!
MIA
Old 10-21-2009, 09:01 AM
Rep: 67 Posts: 243
hi Missing
Jimbo my pipe in but yes, your thinking is right on trac RE: guide coating
Uv light cured resins ? pescaloco Fiberglass and Composite Boat Building 5 06-03-2009 09:14 AM
Mist before epoxy cured tuantom Fiberglass and Composite Boat Building 12 05-05-2009 11:24 PM
UV light cured resin TheFisher Fiberglass and Composite Boat Building 0 06-17-2004 12:39 PM
Completely & utterly off topic Willallison Open Discussion: All Things Boats & Boating 4 08-12-2003 06:39 PM
Completely amateur >70cm RC boat Boat Design 1 09-14-2001 08:36 AM
