Old 04-18-2002, 07:51 PM
chopper gun vs. hand laid
I have seen a lot of argument over the strength differences between a hand laid boat and a boat that is sprayed with a chopper gun. Have there been any studies that show the differences in strength between the two methods? Any direction to this information would be greatly appreciated. Thanks!
Old 04-18-2002, 09:27 PM
Nomad Nomad is offline
Mold Trader/Boat Builder
Rep: 12 Posts: 462
The main diff. is the people doing the work and as long as the boat is not all chop. If done correctly It could be close but the hand laid boats for me are always lighter and stronger.
Old 04-18-2002, 10:49 PM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,648
The main factor affecting the strength of a layup is the glass to resin ratio. The higher, the better. If the skin is vacuum bagged, the chopper gun can get pretty good but otherwise it has a high amount of resin which makes it weaker. Non woven, unidirectional or knitted fabrics can make a stronger layup than woven glass material.
Tom Lathrop
Old 04-19-2002, 10:39 AM
Thanks for the replies, do you know if there are any tests that have been done with regard to this question?
Old 04-20-2002, 06:35 PM
Rep: 12 Posts: 462
No, sorry! Some good points Tom.
Old 04-23-2002, 09:34 PM
Rep: 12 Posts: 462
Stumped again guyz!!!
Old 04-23-2002, 10:12 PM
Maybe it's hard to find test data because it's like comparing apples to oranges ... like tests between a Porsche and a Chevy
Would the test show strength per weight, or weight per boat, or blister problems or ...
There must be some data available (maybe in an archive at Bayliner ), but I must confess I never considered using a chopper gun so I don't know where you would find test data.
Old 04-24-2002, 02:47 PM
Rep: 12 Posts: 462
lol
Old 11-15-2002, 06:47 PM
straycat straycat is offline
Rep: 10 Posts: 2
laminates
To start I would say that the size of this project would dictate the laminate schedule. If this were a 10' dory/dinghy or a shower stall you could probably go ahead and chop it out, keeping in mind that chopped strand or 1.5 oz mat on a roll offer minimal puncture resistance. Lets say this was a 22' project. After applying the skin out in either chopped strand or rolled mat you have to have structure. It matters not, cored or solid glass construction. When comparing "hand laid" glass to something,It usually is against prepreg, scrimp,or custom vacuum assist infusion processes. These processes insure a strong glass to resin ratio. A skilled laminator can deliver a strong hull but it won't compare to a scrimped cored hull. The latter will be stronger,lighter and more uniform than a hand laid cored hull.
Happy boating Phil
Old 12-02-2002, 06:11 PM
sailvayu sailvayu is offline
Rep: 10 Posts: 19
Years ago while working for Caver Yachts (mid 80's) we did run some tests, and surprise the chopper won, but, and this is a big one it depended soley on the operator. You could almost tell who made the lay up by the test results. This is all well and good but you can't chop a full lay up. It saved time and labor for small parts and doing intricate things but in the end you need the directional strength the weaves give you. Thinking about it it seems I might have read about some other tests done in Professional boat builder not sure though. And unfotunatly i no long have access to the Carver data.
Old 01-11-2003, 06:09 PM
Rep: 10 Posts: 2
I am curious as to what types of tests were done what were they simulating?
Old 07-22-2003, 06:31 PM
In my personel experience as a laminator i would never have a boat made with a chopper gun having worked once where it was tried,we soon went back to hand lay up, and i would never do it again and this is also the general opinion of any decent laminator i have worked with over the years.Sure it may be quick , on a flat surface but try spraying somewhere more tricky and getting the correct thickness of glass down, no one can spray as accurate in weight as to when it comes of a roll ie,one part of a square meter might vary considerably to another and any parts you cant get the gun to spray you have to hand lay anyway.Also as someone has said you can't spray a cloth or woven roving etc.The resin ratio can be set but the operator can spray more resin alone if required{all glass needs a certain amount of resin otherwise it is starved and is then weak}.what about the matter of health and safety?I could go on.The only good thing is the percentage of waste goes down.
ps. Someone once told me you can't get a lloyds moulding certificate using this method don't no if this is true however,so perhaps someone could clarify?
Old 01-25-2004, 06:54 PM
guest
the main problem with the gun is getting the thickness uniform,throughout the hull. However assuming that the thickness is uniform, and so the fibre content can be considered to be the same as if it were laid up in chopped mat then you would say that the gun would be more resin rich and therefor heavier for the same strength. really the best and lightest option is to lay up woven rovings over pvc (or any other foam) cores simply for the impact resistance the roving give the skins.
of course like most of the boating industry i have nothing but a little experience to make these conclusions. maybee someone has some homework to do with testing some pannels. id go a 3 point bend(stiffness), repeditive cycle fatigue (not sure how id test that though) and toughness (impact resistence equals ability to absorb kinetic energy). you may want to cut up some chopper gun pannels and see how the thickness varies?
Old 06-29-2004, 08:46 AM
Captain Brad Captain Brad is offline
your choice
Hand laid glass or mat is much stronger if it is applied properly. The essential part of hand laid is to get all air out of the resin and mat. A very good comparison of the two processes is particle board vs solid oak. The less pourous the material the stronger.
Venus Chopper Gun roxyo3boats Marketplace 8 05-17-2006 11:23 PM
chopper gun tom4660 Marketplace 23 05-17-2006 11:15 PM
chopper gun 321 Marketplace 1 10-23-2005 10:06 PM
GS Manufacturing Chopper Gun awake4air Marketplace 0 12-01-2004 05:12 PM
Small air chopper gun awake4air Materials 6 05-06-2004 06:39 PM
