| Choice of MAT vs Woven Roving I receive the price for fiberglass and poly resin from my supplier and I have a question!!! Price are in Canadian $ Polyester resin is sell at $4.22/Kg Mat 1.5 is sell at $4,85/Kg. So at 28% fiber, 1 m2 of laminate of 1mm thickness cost $5.89 Roving 24 is sell at $5.00/Kg, So at 38% fiber, 1 m2 at 1mm tickness cost $9.20 I know that Roving is stronger (about 50% more at 0-90 degres, only 10% more at 45 degres (Hankinson p.87)). If we forget the weight, we can compare 10 mm of roving cost $92.00 / m2 at a 15 mm all Mat laminate. The cost is $88.35. Also the thicker Mat laminate is more stong in fact of is greather tickness. A 13 mm laminate of Mat have probably (means of all direction) the same force that the 10 mm Roving and cost $75.57. About the weight, 13 mm of mat weigh 17.68 Kg and 10 mm of roving weigh 15.85 Kg a difference of 11.5% What is wrong? |
| It is a not a choice of either or you must use csm between layers of roving. CSM< WR>CSM>WR> CSM ETC> |
| If you continue with your sandwich project, I think you can use only bidirectional roving. What happend to the cedar strip planking? |
| LLoyds will OK an all matt boat. It will be heavier than a combo mat & roving boat. You only need 3/4 oz matt between layers of roving for best streingth and lowest weight. FAST FRED |
| If I understand, the choice of all mat boat is correct but it is a economical choice. this boat have higher weight and less performance. |
| Strengh of 24 oz woven vs 15.2 oz Bi-axe | jfblouin | Materials | 6 | 10-06-2005 01:43 AM |
| choice of finish/ choice of lumber | Wood Butcher | Wooden Boat Building and Restoration | 2 | 01-09-2005 03:22 AM |
| Mat, when is it needed | Unregistered | Materials | 4 | 02-06-2004 02:46 AM |
